Ed the Hunter Report post Posted August 27, 2016 I just got a juki lu-562 walking foot sewing machine. I can get it to sew thinner leather, but when I switch to thicker leather, the thread keeps breaking. Would increasing the needle size solve this issue? Quote Share this post Link to post Share on other sites
Handstitched Report post Posted August 27, 2016 G'Day, Have a look at the pic. Spot the difference? theres not a lot in it eh ? That and a Consew 226? It took me a while to figure out why my thread was breaking when I first got my machine some years ago. ( My STW 28-B is now a single needle set up , not a twin needle ) . And even to this day, the same problem occurs occasionally . I use mine for horse rug repairs, medium leathers etc. First, my tension was all wrong. I messed around with the tensioners, so basically now , backed right off and totally loose now, that helped . Thats how it is now, don't ask me why, but it works fine. The second problem is....I think...... is the take up lever. My machine is just over 50 years old , and the holes for the thread in the take up lever are now a bit worn almost to a sharp edge. So every now and then, if/when the thread is at the right 'angle' (?) it 'catches' and cuts the thread . Yeh, I know time to replace it, but apart from that, it runs sweet. I also had a look at the tension spring on the shuttle, as the thread was ' codging' up underneath. You can barely see the tension screw in the pic. So I adjusted that too, it was too loose , all sweet now. There maybe other issues with your machine, but I hope that my experiences may help. All the best HS Quote Share this post Link to post Share on other sites
