Members JasonR Posted September 1, 2016 Members Report Posted September 1, 2016 So, I want to make some leather gauntlets with a scale look.  The problem I'm having is what to use to secure the finger joints that would allow the leather to move.  A rivet will bind it in place but, a chicago screw seems to large.  I don't want to use string as these will be for LARP.  I attached an image that is similar to what I'm attempting to create.  Any thoughts or advice would be greatly appreciated. Quote
Members venator Posted September 1, 2016 Members Report Posted September 1, 2016 Rivet but don't set it as hard as you can? Experiment a bit in how hard you strike it to find a balance of durability and freedom of movement. Quote
Members JasonR Posted September 3, 2016 Author Members Report Posted September 3, 2016 So, i found some 1/8" open back screw post that will work. Â A little wider than I would like but, it will get the job done. Quote
Members TheCyberwolfe Posted September 10, 2016 Members Report Posted September 10, 2016 Take a piece of heavy paper or a chunk of manila folder and use it like a washer around the rivet when you're setting it. Pull it out when you're done, and the rivet won't be so tight on the leather and will allow for movement. Quote -- I don't suffer from insanity, I enjoy every minute! www.rogueleather.com
Members TinkerTailor Posted September 11, 2016 Members Report Posted September 11, 2016 4 hours ago, TheCyberwolfe said: Take a piece of heavy paper or a chunk of manila folder and use it like a washer around the rivet when you're setting it. Pull it out when you're done, and the rivet won't be so tight on the leather and will allow for movement. Beat me to it....I did that trick for a while, now I have a piece of plastic i cut from from some packaging that has a small slit in it, i slip it between the layers of leather with the rivet in the slit, pound the rivet like normal and then slip it out. It is from those packages that you can never open without blood, the ones everything seems to come in now.... Quote "If nobody shares what they know, we will eventually all know nothing." "There is no adventure in letting fear and common sense be your guide"
