Universal Laser Engraver VLS 6.60 - 60 Watt.
I bought this new in December 2010.  It has not seen much use and is in great shape and works perfectly.  It comes with an exhaust blower, upgraded honeycomb cutting table and CorelDraw X4 graphics Suite program to use the laser engraver.  I am asking $17,500 for this whole package.  This is all you need to start engraving and cutting leather.  I have used it to cut up to 14 oz leather.  I am in Temple, TX.  Please direct message me if you are interested.
Thank you,
-Al
Here are the Specs -
Laser Material Processing Area (W x H)
  32 x 18 in
(813 x 457 mm)
Maximum Part Size (W x H x D)
37 x 23 x 9 in
(940 x 584 x 229mm)
Overall Dimensions
44 x 39 x 36 in
(1118 x 991 x 914 mm)
Rotary Capacity
Max Diameter 8 in
(203 mm)
Motorized Z Axis Lifting Capacity
40 lbs
(18 kg)
Standard Focusing Lenses
1.5 in
(38 mm) 2.0 in (This is what this model has)
Laser Platform Interface Panel
Five button keypad
Computer Requirements
Requires a dedicated PC to operate. Compatible with Windows XP/Vista/7 32/64 bit.
PC Connection
USB 2.0
Cabinet Style
Floor-Standing
Laser Options
 60 Watts (this is what this model is)
Weight
325 lbs
(147 kg)
Power Requirements
110V/10A 220V-240V/5A
Exhaust Requirements
Two 4 in
(102 mm) ports 500 CFM @ 6 in static pressure
(850 m3/hr at 1.5 kPa)
  • 3 weeks later...
