Members msdeluca Posted October 25, 2016 Members Report Posted October 25, 2016 I was having trouble with my groover guide riding up on the round beveled edge causing the groove line to be erratic. This groover is made by GoodsJapan... not sure if this is a problem with other manufacturers or if this is just the way this manufacturer makes theirs. My fix was to take the groover bit out of the holder, invert and reinsert it, and belt sand it down about 3/32". The result is that the guide now rides below the beveled edge and maintains a straight groove line. The fix took about 10 minutes. Some pics of the process. Hope this helps. Quote Michael www.conceptleather.blogspot.com www.temptedthreads@blogspot.com
Members TonyRV2 Posted October 25, 2016 Members Report Posted October 25, 2016 I had a different fix...I don't bevel until after I do the stitch groove. Quote Tony VRifle River Leather Ogemaw Knifeworks There are two individuals inside every artisan...the poet and the craftsman. One is born a poet. One becomes a craftsman.
Members cowboycolonel Posted October 25, 2016 Members Report Posted October 25, 2016 I agree with Tony. I also use a groover that is built like a set of diividers. I find it's much more reliable than those light-weight groovers from Tandy. The cutting side is adjustable so you can run the standing side outside of your work, whether beveled or not, and still get a good groove. Quote
Members msdeluca Posted October 25, 2016 Author Members Report Posted October 25, 2016 After sanding, the "skin" raises up and doesn't allow me to see the true edge of the item I'm beveling. I prefer to groove after beveling. I've never seen the divider type. I think I'd still prefer to be visually referencing the finished edge either way. Quote Michael www.conceptleather.blogspot.com www.temptedthreads@blogspot.com
Members cowboycolonel Posted October 25, 2016 Members Report Posted October 25, 2016 Looks like this. ... and you can see everything you are doing.. Quote
Members msdeluca Posted February 17 Author Members Report Posted February 17 On 10/25/2016 at 11:14 AM, cowboycolonel said: Looks like this. ... and you can see everything you are doing.. I can see how the divider type solves the problem. Thanks. I didn't know they exist. Quote Michael www.conceptleather.blogspot.com www.temptedthreads@blogspot.com
Members Beehive Posted February 17 Members Report Posted February 17 1 hour ago, msdeluca said: I can see how the divider type solves the problem. Thanks. I didn't know they exist. Neither did I. Isn't that neat. A divider with a groove cutting head. It even has a wide spot on the other leg. Quote
