Members Bradford Posted October 30, 2016 Members Report Posted October 30, 2016 (edited) Just picked this up in Connecticut today. It appears to be electrified and looks factory, is this the case? Edited October 30, 2016 by Bradford Quote
Members shoepatcher Posted October 31, 2016 Members Report Posted October 31, 2016 I have seen a few of the factory electrified machines. This one has a slightly different motor however with a different clutch on it. Any Singer number or identification on the motor? The table does not have the cast extension piece on the back that Singer came up with to mount the motor. I would say it is not a factory issued set up. However, still could be a Singer motor. I would like to see more pics of the motor. It has the hub and shaft for a front mount wheel which I would change the balance wheel to. Part of the take up adjustment is missing. glenn Quote
Members Bradford Posted October 31, 2016 Author Members Report Posted October 31, 2016 4 hours ago, shoepatcher said: I have seen a few of the factory electrified machines. This one has a slightly different motor however with a different clutch on it. Any Singer number or identification on the motor? The table does not have the cast extension piece on the back that Singer came up with to mount the motor. I would say it is not a factory issued set up. However, still could be a Singer motor. I would like to see more pics of the motor. It has the hub and shaft for a front mount wheel which I would change the balance wheel to. Part of the take up adjustment is missing. glenn Not a singer motor but a GE 1725 rpm motor, might not be a factory install but once I freed everything up it works killer. I was going to get a table and servo motor but this thing is great just like it is. Quote
