I have been experimenting with using para-cord as a stitching material so I dug out some very old scraps to make a side quiver to see how it would do.
Turned out to be a keeper.
Interesting design, not at all what I would call "traditional". Very cool look, I like it.
2 hours ago, Thornton said:
Very nice. Love everything about it except the D ring. Do you use some sort of needle with the paracord?
The D ring was a "let's see if it works" thing. It allows the quiver to be worn on the right or left side by letting the front of the shoulder strap slider to the right or left depending on the side it is worn on. I'm going to work on eliminating that for a no metal build.
I did use a needle. Perma-lok needle Item #1193-01 from Tandy.
