Unfortunately, the stitch length mechanism on the 153's was not a bright spot for Singer. Yours appears to have been set to zero, and then the pot metal threads broke. They almost all fail at some point. There's a fairly simple work around under the cover plate on the top of the machine, near the hand wheel. You'll see some small hex head bolts that hold the eccentrics together. Loosen those up and you can manually adjust the stitch length. A little trial and error will restore your stitch length. After that, as Floyd indicated you'll need to balance out your presser feet motion. You can do this according to the manual which if you don't have one, you can download it. I think you'll find that after you balance you presser feet, you feed dog height will be restored. From your video, the feed cam is moving normal.  I wouldn't adjust any thing until you set the stitch length under the cover plate and adjust your feet motion. These are great machines if it weren't for the design flaw of the stitch length adjustment. I use several for binding. The video shows the cover plate near the end of it. Have fun!
Regards, Eric
6 hours ago, Constabulary said:
Have you tried to adjust to a longer stitch length again?
Hi Constabulary,
Yes but it made no difference. It still sewed in the same hole. 0 stitch length.
thank you for asking though.
Kind regards
Paul
Regards, Eric
Hi Eric,
Thank you for the great advice. I will have a look at it when I get back from work in around 12 hours.
Just one question? What's the eccentrics?
Cheers
Paul
Edited by KeepItSimple
The eccentric is the oblong cam that makes the feed dogs rise and fall.
6 hours ago, brmax said:
At the moment ( first coffee ) the last vid seems to be the reverse or stitch linkage area and shaft, so will have to figure what these parts might have in common with stitch length.
In another step later on the presser feet adjustment, it looks as though the step height/equalization can use adjusting, maybe my morning eyes!
back to adjustment, as mentioned what effect now is any stitch re adjustment, any vids there.
Excellent work and time spent showing the issue
Floyd
Hi Floyd,
Thank you for your observations. I am an absolute beginner when it comes to sewing machines. So it is quite likely that I have made some incorrect assumptions and the reverse or stitch linkage mechanism I videoed is not related to my issue.
I really don't know what things are yet with this machine and did not think it had a reverse mechanism or how that gets engaged.
Thank you to you and all the others here that are assisting with this issue.
I'll have a look later at it when  get back from work
cheers
Paul
Thank you
Well good news guys!
I could not find 2hex bolts for the eccentrics under top cover but noticed the knob for the stitch length adjuster was protuding more than what I would expect. So I gave it a firm tap with my palm and instantly the feed dog started working and the walking action started working. It dies look like the presser feet timing will need adjusting.
