Randy Kildow
SINGER 111W103
I need some help with parts. Have talked to several "SO CALLED" sewing machine parts companies.....  Get the secretary and then No one will call me back.... I need a Singer Industrial parts list and cross reference.  I need the complete rotary hook , bushings and washers for the hook shaft for this machine. This would be easy if I could just reference the parts with update and cross references myself..  Thank You
The hook parts will be the same as a newer style 111w,some other parts like for the walking feet are no longer available for this model.
Here's a list for the hook partshttp://parts.singerco.com/IPpartCharts/111W152.pdf
Yes,we always use & stock the #240558 because it has a better hook guard on it(thicker steel)
