I don't have a critique, but good job.
  • 1 month later...
  • 2 months later...
Great first holster! I would only suggest you pull those stitch lines in a bit. The revolvers, being less square, are much more difficult to estimate the location of the stitch lines than the automatics. You probably have an idea of where you can move them, now that you've made the first one. In the future, with a new model, or with this one, you can use a strip of leather equivalent to the weight you intend to use for the holster to wrap around the gun and get a total circumference. If you are going to wet form, you can case the leather strip prior to measuring. I look forward to seeing your next one.
