Search YouTube for 'sharpening' and watch as many as you have the stamina for, you will start to see how things are done and get an idea of what you think will work for you
Perhaps I'm old fashioned but I just can't get me 'ead round the idea of a sharpening stone that uses water!  so I use a fine oilstone followed by a strop
nevertheless I think this is one of the best videos on YouTube about sharpening. Although it's for chisels the same technique can be used for knives
preparing and sharpening a woodworking chisel by Paul Sellers
You can improve the stitching chisels by polishing the prongs. Use a needle file followed by a home made polishing wand; glue some wet & dry paper onto a sliver of wood or a lollipop stick
If you don't have a needle file use 2 or 2 grades of wet & dry paper. work your way through grades 500 to 1,000
Lubricate the prongs with beeswax to make them easier to insert & remove
Edited by zuludog
1 hour ago, Danno90 said:
Just a quick note to say my kit arrived today, and also some leather, needles and thread in another package from a different company.
Definitely much sharpening to be done. The knife is probably only likely to cut butter at this point - and even then may have difficulty ;) I joke, it seems solid enough, just needs some work on the edge.
Overall pleased with the quality of the set, it just seems a little smaller than I thought. Or perhaps my hands are bigger than I realise having only seen tools in use on Youtube so have no real size comparison. Still, will be more than adequate for now :D
Okay! Good to know. I was worried they might instantly fall apart into dust, since I paid so little for them.  Mine should be here in a couple days as well. Thankfully, I happen to be a female with tiny hands.
Edited by desertwastes
typo
Perfect. I made a note of it, will do. Partway through the youtube video now. Thanks!
He definitely makes it look easy, or maybe that's just me.
As for the beeswax I may have to have a chat with a colleague at work who keeps bees, I'm not sure if it's the right time of year to be after it from the hives but he may have some. And rendering the raw stuff seems easy enough: melt in hot water, pour wax/oil mix into containers to solidify, discard dirty water and take the solid wax out, put wax in double boiler then filter through coffee filter to remove any finer dirt and pour the (now much cleaner) wax into paper cups/cupcake cases to cool into easier to manage blocks. Just thought I'd throw that in there.
I'm being deliberately frugal as I want to get started ASAP with leather but payday isn't for another week...
Once you start looking and Surfing the Net you will see that new sharpening stones are expensive. There are a couple of markets near me with second hand tool stalls; see if there is one near you.
Take your tools along and show the stallholder what you want to do; I have found that they are reasonable and helpful enough
You probably won't find a ceramic or diamond stone as they are relatively recent developments, but you should be able to get an oilstone for £3 or £4. Then you just need some general purpose oil
have a browse round the rest of the stall while you're at it, you never know your luck. One of my local stalls has a box for cobbler's & upholstery tools, I've had a couple of things from him
