If the glue works then fine.But for giggles ,I will tell how I tackled the problem.I haven't posted about the three layer method but have done it and it works, but is somewhat thick.My method for doing it requires a little grinding or filing on the stone to make a lip around the perimeter to make it top hat shaped.I then shape the back of the stone to match the contour of what you are laying it against, inmy case a sheath.Cut a hole in the leather to match the top of the stone and press over.glue and sew the strap on.Davetur3.jpg
Newbie here checking out old threads.....this set is stunning.
