Members Davidmadd Posted June 20, 2017 Members Report Posted June 20, 2017 Hi All I have a Singer 51W54 that appears to be in fine fettle. It is a wheel post feed machine. It stitches just fine, but only if you use the lighter threads. I've been experimenting with thicker threads as I want the threads to form part of the decoration on one or two bags I'm planning in canvas and leather. Now the bobbin mechanism, bobbin size etc appears to be identical to my 111w154 and that machine copes very well with the thicker Bonded Nylon threads, this thread is marked M20. However when I try to use this same thread as the upper or lower thread on the 51W54 it just will not accept it. When I go back to the finer threads the stitches form just perfectly. I have read on this forum previously that this is the case with this machine but I just dont understand why. As I said, it seems to use the same bobbin mechanism as the 111W154 which does sew with the larger threads. Would that perhaps indicate that its the needle side of the equation which is not coping? Any thoughts please. David Quote
Moderator Wizcrafts Posted June 20, 2017 Moderator Report Posted June 20, 2017 While it uses a similar size bobbin and shuttle, the clearances are far smaller than on your walking foot machine. Everything is tighter in those ancient post machines. I used to own two of them and could only get them to sew reliably with #69/T70 bonded thread, tops. Anything larger got pinched and jammed everything up. I would stick to using a #110 needle, with T70 bonded thread, as the maximum. Make sure that if there is a latch opener that it pulls the bobbin case back far enough to let the top thread pass freely around the positioning tab on the case, under the throat plate. Give more thread slack in the check spring. You may get lucky and fool it into passing #92 thread, but you'll need to find a #19 or #20 needle to sew with it. Quote Posted IMHO, by Wiz My current crop of sewing machines: Cowboy CB4500, Singer 107w3, Singer 139w109, Singer 168G101, Singer 29k71, Singer 31-15, Singer 111w103, Singer 211G156, Adler 30-7 on power stand, Techsew 2700, Fortuna power skiver and a Pfaff 4 thread 2 needle serger.
