Azamare
Hot Foil Stamping Machine
Hi, I'm from South Africa.  Want to buy a used Hot Stamping Machine Press but can't find anything about that particular make and model. It's a Colour - Print Mark 3. Made in Demark. The heat setting max is 130 Celsius. Is it hot enough for embossing? Please advise.
Just a thought: Kingsley hot foil stamping machines operates around 200-250°C. Heat is set according to the material to be marked, marking time, foil.  I have an 'Automator (Lyon)' machine, max heat is 300°C. A higher temperature requires a lower time of contact and vice versa.
Sorry: don't know if 130 °C would work for any type of foil. Do you have the chance to test it?
Edited by gigi
