Members Ogoki Posted August 26, 2017 Members Report Posted August 26, 2017 (edited) Hello all, I have been doing some work lately on a Union Special 51900BH. This would have been a triple needle chainstitch machine, but it is operating on one needle only for its current purpose. I have been getting a lot of skipped stitches on the lighter materials. I am pretty sure this is due to the gaping hole in the presser foot around the needle, which allows the sleazier materials to lift with the needle. Does anybody know which presser feet will interchange with this machine? Below is a picture of the one that is currently on there. I see one on ebay (#52820) that looks like it might work, but I would rather not gamble, if somebody knows the answer... http://www.ebay.com/itm/1-new-5280-16-presser-foot-for-UNION-SPECIAL-52800-52900-sewing-machines-/291692870613?epid=1971259328&hash=item43ea3ffbd5:g:TcIAAOSwDuJWzfDX Going by the parts book, it also looks like a #6520 might work, but again, I am guessing. Are there any Union Special experts out there? Thanks for any help. Edited August 26, 2017 by Ogoki Quote Seiko PW-27B, Mitsubishi DN-260, Singer 95K43, Champion 77 McKay stitcher, Champion 55 outsole stitcher
Members gottaknow Posted August 28, 2017 Members Report Posted August 28, 2017 Greetings. I work on Union Special chainstitches every day. I'll check those part numbers for you and can help with trouble shooting. Regards, Eric Quote
Members gottaknow Posted August 28, 2017 Members Report Posted August 28, 2017 Ok, that ebay presser foot #52820 is for a Union Special 51900BZ, which is a chainstitch machine with an optional top cover hook. It's used for sewing pocketing on jeans. I have two of them. The correct part # for your machine is either 51905 A-7 for 6 and 7 gauge or 51905 B-9 for 8 and 9 gauge. You can tell the gauge by the part number on the throat plate. It will be stamped either at the beginning or end of the plate part number with the gauge size. Those two feet may be obsolete. By looking at your picture closer, someone removed a bunch of the foot material which will definitely give you looper skips due to the foot not holding the fabric secure so a loop can be formed on needle bar rise. There is no cure with the exception of a new foot. With thicker material, it has a better chance of not skipping. There's a good chance I have a foot around that will work. I just need to know the needle gauge as I mentioned above. Let me know if you like. Regards, Eric Quote
Members Ogoki Posted August 31, 2017 Author Members Report Posted August 31, 2017 Hi Eric, Thanks for the response! I will check the number on the throat plate next time I'm there. Right now I am using a size 20 needle, if that helps you any. Are those part numbers meant for this machine in its stock, 3-needle operation? Or are they single-needle variants? Also, is it really not possible to adjust the stitch length on this machine? I have been told it isn't, and I don't see any obvious way to do so... Thanks again. Kevin Quote Seiko PW-27B, Mitsubishi DN-260, Singer 95K43, Champion 77 McKay stitcher, Champion 55 outsole stitcher
Members gottaknow Posted August 31, 2017 Members Report Posted August 31, 2017 Those part numbers I mentioned were for the machine as it came from the factory. In your case, a 3 needle chainstitch flat felling machines. There are no less than 20 machines of this same casting. Union Special never intended a machine to be modified, so there's no part numbers for variations, except for gauge size. It's true a lot of the parts can interchange, including the presser foot. The foot you saw on eBay isn't for any of the sub-classes. If the needle slot is centered for your needle, then great. Most chaining feet have a small groove for proper thread chaining. Also, you should be able to change the stitch length. I'll try and attach a PDF with how to do it. All these subclasses use either class 128 or 108 needles available in many point types and size. Regards, Eric Quote
Members Ogoki Posted August 31, 2017 Author Members Report Posted August 31, 2017 OK, so I guess my best bet is to find the original 3-needle foot. I just found the Union Special parts manuals and it seems that the part numbers are 35820 P-8 and P-9, if that makes sense. Those stitch-length instructions would be great, if you have them. The stitch length on this particular machine is rather long and it looks kind of ugly... The Union Special site just seems to have parts manuals, which do have basic oiling and threading instructions, but that seems to be it. Thanks again. Quote Seiko PW-27B, Mitsubishi DN-260, Singer 95K43, Champion 77 McKay stitcher, Champion 55 outsole stitcher
Members gottaknow Posted September 7, 2017 Members Report Posted September 7, 2017 Here is a PDF to show you how to change the stitch length. I haven't had a chance to look for a foot yet. Regards, Eric US51900BH.pdf Quote
Members Ogoki Posted September 8, 2017 Author Members Report Posted September 8, 2017 Much appreciated!!! Quote Seiko PW-27B, Mitsubishi DN-260, Singer 95K43, Champion 77 McKay stitcher, Champion 55 outsole stitcher
Members Ogoki Posted September 12, 2017 Author Members Report Posted September 12, 2017 I set the machine to a stitch length that looks much nicer, but it started skipping stitches like crazy. So, I backed it off and seem to have found a sweet spot where it skips very rarely, but is still too long for my liking. Any ideas as to why it wouldn't loop properly with a shorter stitch length? Does tension generally need to be adjusted with stitch length on one of these? Or does that sound like it needs a needle/looper/timing adjustment? If so, is there a proper manual for these things with an "Instructions for machinists and adjusters" section? I am happy to improvise with my own machines at home, but not so much at this job... Quote Seiko PW-27B, Mitsubishi DN-260, Singer 95K43, Champion 77 McKay stitcher, Champion 55 outsole stitcher
Members gottaknow Posted September 12, 2017 Members Report Posted September 12, 2017 Setting a chainstitch properly is nothing like setting a lockstitch. There is an entire different set of parameters, terminology, and troubleshooting requiring a different skill set. There are manuals still available from Union Special's website, however without a basic understanding of how a chainstitch works, you will likely struggle. Before you do anything, I'd get a different foot to eliminate the flagging issue. After that, I can give you an outline of how to proceed. There are some general guidelines that are common to all chainstitch machines. One thing's for sure it will never be the fault of the bobbin case. Regards, Eric Quote
