This sounds like a thread problem. Buy different thread and try again, top and bottom.
Posted IMHO, by Wiz
Watching closely as it was stitching just now, I noticed that the center foot is way above the material when it's pulling the stitch tight.  Not sure if this is how it's supposed to work, but it doesn't seem right.  Almost like if you tried to sew with the foot up on a regular machine.
Edited by mwpdx86
Nope. That is not how it should be. The inside foot is usually adjusted so it hits the material just as or after the tip of the needle. It should stay on the material until the needle has lifted out of the material, or at least almost until then. You can raise and lower the inside foot, as per your user manual, to get this to happen. It is the inside foot that raises and lowers the presser foot. When the inside foot begins to lift off the material, the outside foot should be smack down on the top layer, holding it in place.
Posted IMHO, by Wiz
I think that's how it is.  I meant that the inside foot is off the material when the take up lever is pulling up on the thread so the material sort of puckers/lifts.
Do you have any recommendations for a brand/type of thread that should work? The stuff I got was just whatever bonded nylon machine thread they had at the local leather place.
Thanks!
Thanks!
I buy thread from many sources. Sometimes even a formerly perfect spool from a supplier will cause problems with the next spool I open. I try to find Made In USA or Canada (Cansew) thread. Otherwise, I buy Cowboy brand bonded nylon and polyester thread from Toledo Industrial Sewing Machines, or, once in a while, Weaver's heavily lubricated bonded nylon thread..
Posted IMHO, by Wiz
