Ornito Report post Posted September 24, 2017 Hello everybody, I can get one of these machines and I' d like to know what's the " best" for leather (up to 5/8") (bags, satchels, suitcases - mostly glued layers) Pfaff 335-900 or 910 or 911 Pfaff 596 Durkopp Adler 239 Durkopp Adler 269-373 Durkopp Adler 69-FA-373 thanks in advance ! (this forum is AMAZING, thank you all!) Quote Share this post Link to post Share on other sites
Uwe Report post Posted September 24, 2017 (edited) None of the machines in your list are designed to sew 5/8" of glued leather. You really need a Durkopp Adler 205-370 or a Juki TSC-441 class machine to sew material that thick and hard. Out of the machines in your list, the Durkoppp Adler 269-373 is the most capable in terms of material handling and it would make a great companion to a Durkopp Adler 205-370. Edited September 24, 2017 by Uwe Quote Share this post Link to post Share on other sites
Ornito Report post Posted September 24, 2017 (edited) 46 minutes ago, Uwe said: None of the machines in your list are designed to sew 5/8" of glued leather. You really need a Durkopp Adler 205-370 or a Juki TSC-441 class machine to sew material that thick and hard. Out of the machines in your list, the Durkoppp Adler 269-373 is the most capable in terms of material handling and it would make a great companion to a Durkopp Adler 205-370. Thank you Uwe, what it should be the thickness limit ( or the thickness operative range) for the Durkopp Adler 269-373 ? Edited September 24, 2017 by Ornito Quote Share this post Link to post Share on other sites
Uwe Report post Posted September 24, 2017 In general, industrial sewing machines are designed to sew whatever thickness you can fit under the raised feet. Maximum foot lift is the material thickness the machine should be able to handle. According the Duerkopp Adler 269 Brochure the machine is designed to sew material up to 10mm thick. By comparison, the Duerkopp Adler 205-370 Brochure Is designed to sew material up to 20mm thick. The 5/8" (16mm) thickness you mentioned is way above the range the DA 269 can handle, but well within the range the DA 205 can handle. Quote Share this post Link to post Share on other sites
Ornito Report post Posted September 24, 2017 Thanks !! Quote Share this post Link to post Share on other sites
