Members JessH Posted September 30, 2017 Author Members Report Posted September 30, 2017 On 25/09/2017 at 2:09 PM, machinehead said: Do what Bob says and all will be well for you. When you speak of a 16 needle being dainty, you are confusing the size of the needle eye with a system ( or in older reference a class) 16 needle. To confuse you further, the 135x17 needle that Bob refers to is for textiles , artificial leather and sometimes soft garment leather, but the same needle with a leather point is 135x16. These needles come in a wide variety of eye sizes as well as different shaped leather points. Thanks very much guys, The needle bar is so obvious once you point it out . Yes I went onto ebay, posted 135/16, and loads popped up straight away thank goodness, so am ordering them and the 17's. I was beginning to panic I'd bought a machine that would be obsolete when my half dozen needles ran out... Huge relief, thanks so much, and one of the benefits of the internet, as without it, you would never have known how much I needed all your bits of info! It's also possible you've sorted a conundrum, I was given 2 plastic packs of needles, both half empty, and on putting them all into one, I found four of the needles are 2mm shorter, so based on your advice, I wonder if they are 135/17's? Not sure which is in the machine, as don't feel like fiddling with that needle just yet, if it ain't broke, don't fix it! . Re scarves, the longer needle has a scarf with a ridge either side, while the shorter has a completely flat scarf, though you say the 16/63 doesn't have one at all, so could these both be 135's even though 2mm different? I see from my earlier comments I still didn't understand the needle system when these numbers were first offered. Pretty sure I finally do, and thanks for your patience. Quote
Moderator Wizcrafts Posted September 30, 2017 Moderator Report Posted September 30, 2017 If it helps you, the System 135x16 and 17 needles are 1.75" long. They are ubiquitous and used in a huge percentage of walking foot machines, as well as Singer patchers. If the machine was designed to use a longer needle system and you adjust the needle bar for System 135x16, you'll lose some of the clearance and lift that was built into the machine. If most of your work is under that height it won't matter too much. Quote Posted IMHO, by Wiz My current crop of sewing machines: Cowboy CB4500, Singer 107w3, Singer 139w109, Singer 168G101, Singer 29k71, Singer 31-15, Singer 111w103, Singer 211G156, Adler 30-7 on power stand, Techsew 2700, Fortuna power skiver and a Pfaff 4 thread 2 needle serger.
