For sale in Continental USA only.
This is a used Schaefer EC model edge coating glue machine 11” wide.
Please take note that this is a 110v Power machine.
This machine is in good condition and easy to clean up after use, I do not have the manual for this machine but one is not required, simple to use. Description below is from the Schaefer website.
Shipping weight is about 120lbs on pallet, I will palletize and pack this machine, you will need to arrange a shipper to pick it up.
Machine costs $5495 new.
Asking $1300
Reply through this forum or you may call the shop at 602-two69-zero202.
Thanks for looking.
Edge Coater - EC Series
Edge Coating Machine (model EC): The EC model is an edge gluer, which is a gluing machine designed for adhesive application along the edge of a part. This type of gluing machine has open
end (cantilevered) rollers that allow adhesive application to either the edge of a sheet or to the full
surface (up to the width of the gluing machine).
The adhesive coating thickness is adjusted by means of a dial which controls the gap between the pickup
roller that sits in the glue tank and the coating application roller.
The standard machine can glue parts from paper thickness to ¼ thick, but an optional model with floating
feed roll can be used for adhesive application to parts up to 2" thick.
The position of the feed table relative to the coating roller is adjustable so the machine can be set for
gluing a narrow strip along the edge of a part or can be used for adhesive coating of the full surface. The
edge cementing machine can be built with special rollers for coating stripe patterns or for application of a stripe of adhesive a pre-set distance from the edge of the part.
The Edge Coater can be used for the application of many types of adhesives - latex cement, dextrine glue,
PVA and EVA resin cement, acrylic PSA adhesive, epoxy adhesive, ultraviolet cured adhesive, hot animal
glue (heated glue tank), and many other types of coating and adhesive formulations. The machine is
designed for easy cleanup, and has a removable glue tank and adhesive pickup roller. This design allows
glue to be cleaned from the machine in less than ten minutes.
Edge Coating machines are very popular for the application of latex cement to leather goods such as
wallets, handbags and belts, as well as to shoe and boot components. These machines are also used for
gluing many other products where a band of adhesive is needed: calendars, easel backs, sample books, specialty boxes, filters and toys are just a few of the other applications for these machines.
International Handgun Leather
Since 1994
Martin & Son Makers
Est. 1994
www.ihlusa.com
