Members Firewalker Posted January 3, 2018 Members Report Posted January 3, 2018 On 11/26/2017 at 4:58 PM, TSes said: Hopefully, the shop owner wants the finished product in his shop. That way you won't have to take time to fit each one. We keep size 30 through size 50 in stock at all times. His sales will determine what is best for you. Usually, 36 through 44 make up most of our sales. This is for a standard, not fancy belt. The first thing for you to do is make a specific sized belt in your normal way. We make only even numbered sizes (32-34-36-etc.). We make our center hole 5 1/2" from the tip, and add 3 1/4" at the buckle end. Take the belt apart, and measure the total length. Then subtract the size of the belt, and the remainder is the amount to add on to any size you need. Using our measurements, a size 40 belt would need a blank of 48 3/4". A ranger style or lined belt won't work using this formula. We only use 2 buckles. Stainless or brass of the same design. Too many options mean more precise measuring. Hope this helps. That is a solid answer! Well done. Quote Follow me here ---> https://www.instagram.com/campbell_leatherworks/
