Members olwaylon Posted August 2, 2018 Members Report Posted August 2, 2018 Hello, I'm using the resolene as a resist. Using a light coat antiquing. Now, will the resolene stay sealed over the Super Sheen? Thank you so much. Quote
NVLeatherWorx Posted August 5, 2018 Report Posted August 5, 2018 On 8/1/2018 at 7:53 PM, olwaylon said: Hello, I'm using the resolene as a resist. Using a light coat antiquing. Now, will the resolene stay sealed over the Super Sheen? Thank you so much. For clarification are you using the Resolene or the Super Sheen for the resist? Your original question leads one to believe that you used the Super Sheen and then finished with the Resolene. Once you apply your resist you are in essence sealing the pores of the resisted areas which is what limits the color penetration from being as bold as the unresisted areas. After you have all of your coloring finished and buffed out properly so there is no residual, you can apply whatever you want as your final seal and it will do its intended job regardless of what you have done up to that point (in other words, it will even protect those areas that have been resisted). Quote
Members olwaylon Posted August 6, 2018 Author Members Report Posted August 6, 2018 Thank you! And yes, I should have proofread before i pressed send! Quote
