Jlev111 Report post Posted September 29, 2018 Hey there guys! I just picked up a Juki Lu562! I was excited, and found out I’d need to replace the timing belt. I haven’t been able to find any info about how to fix it. The manual is hard to understand. Any tips, or videos that demonstrate the removal of a timing belt on an Lu562? Quote Share this post Link to post Share on other sites
Uwe Report post Posted September 30, 2018 That's not a simple task. The closest thing to a video is this one (https://youtu.be/TIxQViDgL1c) showing the procedure for a Singer 111W. On your Juki LU-562, you also have to remove your reverse handle bar. If you're new to sewing machines, I'd recommend paying a capable mechanic to replace the belt. If you're mechanically inclined and you can live with the machine being down for a few days or weeks or forever, you can start exploring. Quote Share this post Link to post Share on other sites
Jlev111 Report post Posted October 12, 2018 Thanks Uwe! That worked wonders. Any tips on reinserting the spring? Also I had to realign the feet on the machine. Now the presser foot is not moving at all... any tips? On 9/30/2018 at 4:35 PM, Uwe said: That's not a simple task. The closest thing to a video is this one (https://youtu.be/TIxQViDgL1c) showing the procedure for a Singer 111W. On your Juki LU-562, you also have to remove your reverse handle bar. If you're new to sewing machines, I'd recommend paying a capable mechanic to replace the belt. If you're mechanically inclined and you can live with the machine being down for a few days or weeks or forever, you can start exploring. Quote Share this post Link to post Share on other sites
