Members Steve223 Posted January 2, 2019 Members Report Posted January 2, 2019 I have a Consew 223 that I bought cheap and it runs good on a clutch motor but it ran too fast. I didn't know much about it and had other machines that sew light leather and decided to buy a servo motor. Well before you know it a few years pasted and I decided to connect it up. I have the speed corrected now and noticed when reading the online operations manual that it should have a knob on the side to set stitch length. It has no knob or markings. The front of the machine has the main body casting of the 223r with someone putting white paint over the r on the model # and all the reverse stitch length parts are missing and a cover over the hole. I watched videos on the 153w100 and the stitch length adjustments look the same. Mine is locked in one stitch length. you can't move it. It sounds like someone hacked this thing together or maybe it is set for one use in a factory. I can post pictures if anyone would be interested in giving pointers on what is missing or needed to make stitch length variable. I didn't see much online as far as service manuals. It works and honestly the one stitch size is just fine while I am just starting to sew leather with this type of machine and for the price I paid was under $200 I am not too concerned. Thanks for your time! Quote
Members Constabulary Posted January 2, 2019 Members Report Posted January 2, 2019 Picture tell more than 1000 words... Quote ~ Keep "OLD CAST IRON" alive - it´s worth it ~ Machines in use: - Singer 111G156 - Singer 307G2 - Singer 29K71 - Singer 212G141 - Singer 45D91 - Singer 132K6 - Singer 108W20 - Singer 51WSV2 - Singer 143W2
Members Steve223 Posted January 6, 2019 Author Members Report Posted January 6, 2019 (edited) I have some pictures now. I have pictures of the insides also if needed. I think the adjustment is broken off in the wheel and the needle is missing. Edited January 6, 2019 by Steve223 Quote
Members Steve223 Posted January 6, 2019 Author Members Report Posted January 6, 2019 I have some pictures now. I have pictures if the insides also if needed. I think the adjustment is broken off in the wheel and the needle is missing. Quote
Members Steve223 Posted January 6, 2019 Author Members Report Posted January 6, 2019 I am missing the needle for adjusting the machine but the threads are good and the adjustment length is almost totally open. Pictures of the hole and the threads are posted. Can you get the pin at all? I would hate to modify the machine. Quote
Members Constabulary Posted January 6, 2019 Members Report Posted January 6, 2019 (edited) Seems the 223 came with 2 different stitch length mechanisms - one just as used on the Singer 153 (old type) and one with a stitch length / reverse lever (later type). I would open the top lid and check what inside there and find out which type of stitch length mechanism is inside the machine. But I think you are right seems someone "cobbled together" 2 different machines (see lever marks on pics 2 + hand wheel with coarse thread seems to be from the 1st type) - or - it is a custom build / modified machine but I cannot tell from your pictures. I just looked for pictures: Edited January 6, 2019 by Constabulary Quote ~ Keep "OLD CAST IRON" alive - it´s worth it ~ Machines in use: - Singer 111G156 - Singer 307G2 - Singer 29K71 - Singer 212G141 - Singer 45D91 - Singer 132K6 - Singer 108W20 - Singer 51WSV2 - Singer 143W2
Members Steve223 Posted January 6, 2019 Author Members Report Posted January 6, 2019 Thanks for your help! It looks like the older one but I have a few pictures to share. I don't have movement of the slot to adjust stitch width. It is hard for me to tell not ever seeing a good one!. Quote
Members Steve223 Posted January 6, 2019 Author Members Report Posted January 6, 2019 Oh, The hand/pulley wheel looks like the white machine. Basically the white machine with no lever. With guts of the old machine. I will shoot more pictures in the morning. Quote
