  • Ambassador
this is what i built its not the best but works just fine and cost next to nothing as it was built from scrap timber i had laying around, as Bruce mentioned about working on the ground seat i thought up a strap like on a center fire saddle, and when working on the fork or cantle i just change the strap you can see hanging at the rear underneath
Man, every time I log on I see another idea I can steal...I mean - incorporate! Great idea Don!
My choice early in life was either to be a piano-player in a whorehouse or a politician. And to tell the truth, there's hardly any difference.
Harry S. Truman
One more quick idea on a simple remedy for the ratchet catch. Just go down to the hardware store and look in the section where they sell the replacement saw blades for the "Sawzall" type products, and there you will find a ready made ratchet. Just drill a couple holes and attatch to your frame with some good screws. Cheap, quick, and works fine!
After some folks tell you all they know, they keep on talkin'
The ratchet bar on my draw down is the bar from a ratchet type fence stretcher. If you cut them in half you have enough for two draw downs. Didn't cost me a penny
"If you see your stirrups slap together above the saddle horn, you're probably bucked off"
Dave Stamey, The Bronc Ballet
  • 1 month later...
My old draw down is strating to split and I got tiered of jumping up and down on the bar to get a tight fit, so I found a sissor jack out back and use it now. I may switch to a small bottle jack one of these days. Small mods and I'm on my way. Just hope the O/L doesn't get a flat first. HA!!
G.Hackett
You did What??
