I want to cover a plastic discbound journal in leather like in the picture. How can I hand-sew the leather onto the plastic part? Would a contact cement work well instead of sewing?
To hand sew to plastic your best option is to drill your stitching holes with an appropriately small bit. If you have a drill press, that is your best option. Even a handheld rotary tool or drill will get you what you need, just have to be a bit more careful about maintaining a consistent, vertical hole.
Contact cements will work to attach the leather to the plastic, but retention is a big concern. Since you’re taking the time to make the leather cover, I’d assume you want the cover to be used through multiple sets of page inserts. In that case I would not personally trust an adhesive to do the job.
I think most of these binder/folio/book covers are made as a slip-on. So stitching on 3 sides and the 4th open side allows the plastic part to be inserted.
This could be done as 1 piece cover with back, front and cover over the ring binders, or a 2 piece cover with separate back and front, with Velcro to keep the covers in place.
If you wanted to fix a single thickness or leather to the cover, I would do what @heydox suggested with glue-ing the leather to keep it in place, then drilling holes about 3mm (1/8") in from the edge and stitching (or lacing).
You could stitch a fancy pattern on the cover by placing a stencil and drilling holes where required. Its all up to your imagination.
Kindest regards
Brian
"Whether you think you can or whether you think you can't, you are right"  Henry Ford
Machines: Singer 201p, Kennedy,  Singer 31K20, Singer 66K16 ("boat anchor" condition), Protex TY8B Cylinder Arm (Consew 227r copy), Unbranded Walking Foot (Sailrite LSV-1 copy)
