sinpac
singer 211g155
I am trying to run t135 thread in the bobbin. I noticed there is no tension on the thread. I tried tightening down the tension screw but with no luck. the tread as no tension on it. Do I need a new bobbin case or maybe a new tension spring. Or am I on the wrong path on my thinking?
Chris
Chris
Also would like to know. If the feed dog is not running parallel to the foot, will that make the item you're trying to sew want to drift off line?
