Members RWL2 Posted June 15, 2020 Members Report Posted June 15, 2020 From browsing posts on these machines, it seems some of you have adjusted your machines to use commercial round shank industrial needles, which you can get in larger sizes and different points than the 15x1 / HAx1 domestic needles typically used in these machines. My impression is that the changes are minimal adjustments rather than permanent modifications to anything like drilling the needle plate hole larger. An industrial needle will be held about .014" to the left because of the absence of the flat. The holes in the casting of he machine are more oversized than that so it wouldn't be hard to move the bed/table a little to the left to recenter an industrial needle. I guess you might have to adjust the sliding rack / shuttle drive bar a smidge to get the timing right and change the height of the needle bar since the industrial needles are longer. No drilling the needle bar, right? Am I missing anything? Which system of industrial needles to use 134 or 135x16 or 135x17 and why? Quote
Members veedub3 Posted June 16, 2020 Members Report Posted June 16, 2020 Go to this Facebook Group and in the files section there are directions on making Needle Bar Modifications that are quick and easy that will allow you to use Industrial needles. The only tool I needed to do the modification was a jewelers file. https://www.facebook.com/groups/1646031288779869/ Karina Quote "The only man who makes no mistake, is the man who does nothing." Theodore Roosevelt
Members RWL2 Posted June 16, 2020 Author Members Report Posted June 16, 2020 (edited) The problem I have with the Facebook instructions is that it requires filing of the needle bar which permanently alters it so you can't revert back to 15x1 needles if desired. According to comments made by Darren B in this thread: it sounds like you don't need to file the needle bar and permanently alter it. The round shank industrial needles are held adequately without any permanent modification of the needle bar and all you have to do is loosen the three bolts on the bottom of the arm's casting and move the bed roughly 0.015" to the left to accommodate the new position of the industrial needles. I did pick up from the Facebook group's needle modifications file though that 134x5 and 135x5 class needles are the easiest choice since they're the same length as the 15x1 needles and don't require changing the height of the needle bar. I'm guessing that if you're sewing really thick material / leather you go to the 135x16 / 135x17 needle system since they're about 1/8" longer and I think those come in larger sizes to accommodate even heavier thread. I had hoped to see if anyone here besides Darren had done this and what their experience had been. Just for purposes of keeping all the information together for future reference. 134x5 is also known as 134D, 135×7, 135×25, 1901, DPx5, and DPx7 according to http://southstarsupply.com/product/schmetz-needles-134r-135x5-135x7/ It's a confusing system. 134x5 needles are available in both sharp point and leather point although leather point needles seem to be less common in this system. I'm not sure how 135x5 needles are different from 134x5 needles. The 135x16 are leather point needles and 135x17 are sharp point needles for fabric. Edited June 16, 2020 by RWL2 Corrected grammatical error in first line. Quote
Members wolf1 Posted November 16, 2024 Members Report Posted November 16, 2024 former machinist turned retired leather holster maker. is there a reason you can't grind/file a flat on the needle shank? just got a chinese shoe patcher and wanting to run 140/22 needles with 207 thread. Quote
