Completely at a loss at how in the world to use this tool. If you have this tool, please explain how you get the basketweave with this thing.
Thanks in advance....**Note time of post and frustration levels**
  • Ambassador
Have a look at this seat that Beezachopper did, it has that style of basket weave on it. I hope this helps.
Seat with Basketweave
Ken
When ever you get a new tool at TLF or TANDY they have a marble slab and a scrap piece of leather and are usually very adept at showing you all the different ways of using it. Also they make these sheets called 'craftaids' that explain things as well and give ideas on different applications. I'm not at home now but there is also a way to make a pattern with that tool that leaves tear drops! I can't explain how but you can also get layout templates that have the width to set you lines to make things straight or you can make one yourself for each tool.
Vaya Con Dios, Alan Bell
Things are not the way they used to be; One and all, we got to face reality now
Bob Marley - 'Natural Mystic'
Attached is a sheet from Tandy that shows how to use the tri-weave tool. Hope this helps.
Russ
Forgot to upload the attachment, will try again.
Russ
