Members Memphis514 Posted October 4, 2020 Members Report Posted October 4, 2020 ok so i have a CB3200 and on the threadexchange site they say you can run 277 thread through 180/24 and 230/26 needles. what would be the advantage to running this thread through different sizes of needles? TIA, Memphis Quote
Moderator Wizcrafts Posted October 4, 2020 Moderator Report Posted October 4, 2020 I would only use an oversize #230 needle if the bottom of the hole healed up before the knots can be pulled up. This might happen on Biothane harness or heavy webbing straps. For instance, I occasionally get hired to sew vehicle tow straps that are 2 inches wide and about 1/4 to 5/16 inch thick along the overlap. I use #346 thread with a #26 needle to offset the hole bottom closing up. This makes it easier to pull up the knots and center them in extremely dense material. Quote Posted IMHO, by Wiz My current crop of sewing machines: Cowboy CB4500, Singer 107w3, Singer 139w109, Singer 168G101, Singer 29k71, Singer 31-15, Singer 111w103, Singer 211G156, Adler 30-7 on power stand, Techsew 2700, Fortuna power skiver and a Pfaff 4 thread 2 needle serger.
Members Memphis514 Posted October 4, 2020 Author Members Report Posted October 4, 2020 16 hours ago, Wizcrafts said: I would only use an oversize #230 needle if the bottom of the hole healed up before the knots can be pulled up. This might happen on Biothane harness or heavy webbing straps. For instance, I occasionally get hired to sew vehicle tow straps that are 2 inches wide and about 1/4 to 5/16 inch thick along the overlap. I use #346 thread with a #26 needle to offset the hole bottom closing up. This makes it easier to pull up the knots and center them in extremely dense material. i am just sewing normal veg tan so basically i should use the smaller needle on the list? Quote
Moderator Wizcrafts Posted October 5, 2020 Moderator Report Posted October 5, 2020 6 hours ago, Memphis514 said: i am just sewing normal veg tan so basically i should use the smaller needle on the list? No. I use a #25 needle with #277 thread. A #24 needle hole is too tight to let the knots come up easily in veg-tan leather. You would have to really crank down the presser foot pressure screw and crank up the top tension, and/or lower the bobbin tension. Quote Posted IMHO, by Wiz My current crop of sewing machines: Cowboy CB4500, Singer 107w3, Singer 139w109, Singer 168G101, Singer 29k71, Singer 31-15, Singer 111w103, Singer 211G156, Adler 30-7 on power stand, Techsew 2700, Fortuna power skiver and a Pfaff 4 thread 2 needle serger.
Members Memphis514 Posted October 9, 2020 Author Members Report Posted October 9, 2020 On 10/4/2020 at 8:32 PM, Wizcrafts said: No. I use a #25 needle with #277 thread. A #24 needle hole is too tight to let the knots come up easily in veg-tan leather. You would have to really crank down the presser foot pressure screw and crank up the top tension, and/or lower the bobbin tension. Well I'll be damned the #25 worked flawlessly...thank you Quote
