Members shoepatcher Posted October 31, 2021 Members Report Posted October 31, 2021 evilblackdog, The unit on the back of the machine is called a Dimas unit. It was made by a company in Denmark for the 1295, 345, 335, 1245 to put toys on the machine. You can order the front stitch length plate and the reverse lever rod form Pfaff. You will also need a standard throat plate, feed dog, inner and outer feet. Save all the Dimas parts. I have worked on them and that unit is no longer made. You can remove the trim knife as well from near the hook. Take motor, control box off. Contact me with anymore questions. Obviously, you will need a servo motor. Save all parts.!! glenn Quote
Members evilblackdog Posted November 1, 2021 Author Members Report Posted November 1, 2021 On 10/30/2021 at 5:13 PM, dikman said: Impressive. I've only seen photos of Efka units on machines, and no details. Edit: manuals here - https://www.manualslib.com/products/Pfaff-335-3541803.html It's the "new" model, btw, not the old casting. It will show you what the missing reverse/stitch length lever looks like and you should be able to work out what the various added-on bits do. Those levers on the back would have been added to allow for the automation of foot lift and maybe tension? Usually the mounting hole spacing for clutch motors follows a standard 3-hole pattern and a servo should line up with the same holes. The only real problem I see is finding the replacement stitch length lever. Because the 335's were sold as "plain" machines there's no reason this one can't be returned to that state. Thanks a lot for the info. Do you know how many generations there are in these things? You say it's the "new" casting but it doesn't look much like the ones they're currently selling so I'm curious how many versions there are. I'm also struggling to find the serial number to confirm as it doesn't seem like any of the numbers on the name plate have the correct number of digits. Thank you for linking the manual, it had some enlightening stuff in there. I thought the solenoid on the inside was an aftermarket add-on but apparently it's the factory option for a thread cutter although I'm still a little confused because it relies on the variostop controller to activate it which I thought was aftermarket as well... One of the arms on the back is connected to the pneumatic cylinder that lifts the foot and the other does control thread tension but it's tied to the solenoid that is for the thread cutter. Does it just modify the tension when it needs to cut the thread? Thank you so much for the help. I love mechanical things and I will figure this out, It's just difficult when I'm starting from scratch when it comes to how these things operate. Quote
Members evilblackdog Posted November 1, 2021 Author Members Report Posted November 1, 2021 15 hours ago, shoepatcher said: evilblackdog, The unit on the back of the machine is called a Dimas unit. It was made by a company in Denmark for the 1295, 345, 335, 1245 to put toys on the machine. You can order the front stitch length plate and the reverse lever rod form Pfaff. You will also need a standard throat plate, feed dog, inner and outer feet. Save all the Dimas parts. I have worked on them and that unit is no longer made. You can remove the trim knife as well from near the hook. Take motor, control box off. Contact me with anymore questions. Obviously, you will need a servo motor. Save all parts.!! glenn Would you be open to a quick phone call? (I'm self employed so anytime that's convenient for you would be fine.) You're the first person to tell me what that thing is called and I'm struggling to get the right questions into text since I don't know the propper lingo yet. I'll direct message you with my contact info so you can call when it's convenient if you'd like. Quote
