Ok, I am totally finished with the tools.... Along with the above mentioned method of cleaning the tooling heads of the tools, I then took everything over to the work bench and put the "brass" colored 8" wire wheel onto the grinder along with the cardboard buffing wheel I have been using from my buffing/sharpening kit. I used the wire wheel to clean all the shafts of the tools... on several there was a minute speck of rust on the shaft and when i hit it with the wire wheel it removed it along with the plating showing allot of rust beneath the plating. I was able to clean all this up and put then on the buffer using white compound and buffed the metal to a nice shine.... some of them (more vainers' than anything else) had under the plating rust all the way to the tip of the tooling head so I knocked it all off.... the metal was in good shape and buffed up nicely.... on a few the tools had been banged around where the tooling pattern was slightly messed up and I buffed them as well as I could and left them... I will keep them as they.... give them character I hope... all in all I only lost one tool in this whole thing and it was the very small pear shader that I tested the 8" wire wheel on and the wheel tool the tooling pattern off the head.... I smoothed it out and buffed it to a shine so i can use it as a smooth pear shader instead of a patterned one...
I will get pix as soon as I remember to get the camera back from the wife.....
Now to start another thread asking for pix of tool boards... I have over 400 tools and need ideas on how to make tool caddies to hold em all in....
"The miracle is not how two adults can create a child, the phenomenon is how quickly a child can create two adults." -- VYBE
Her: Hit Me
Him: Do you want me to use the knife?
Her: No, When you hit with a knife, that's STABBING!
  • 2 weeks later...
  • Replies 32
  • Created
  • Last Reply
Top Posters In This Topic
My brother told me coca cola will remove rust off chrome. He uses that on cars. I wonder if the cream of tarter would have gotten to all the rust uner the plating.
Bev
I found a non toxic chemical I have used for old gun parts and gunsmithing tools. It's called Evapo Rust. Put some in a pan. drop the tools in and wait a day. It takes all the rust off and also adds a coating to boot. You can keep reusing the same stuff until it stops working. I have used it on old tools, old gun parts, old reloading dies, and it works great.
Last time I checked, the Auto Zone was supposed to start carrying it. I get mine from a place called The Rust Store!
Jim
