Sew Zipper On Case
  • Please log in to reply
7 replies to this topic
#1 xlr8tn
xlr8tn
    Member
  • PipPip
  • 114 posts
  • Leatherwork Specialty:Custom Watch Straps
Posted 01 December 2013 - 09:03 AM
Hey all,
I haven't yet installed a zipper on any project I have made. I would like to make a gun case and have a multi-direction zipper that can be locked. Does anyone have an article or link on how to go about sewing a zipper like this:
http://www.santassle...com/ruger1b.jpg
Thanks,
Brent
#2 RiverCity
RiverCity
    Member
  • PipPip
  • 240 posts
  • Gender:Male
  • Interests:Sheridan carving. Case making.
  • Leatherwork Specialty:Measuring twice and still cutting it short.
  • Interested in learning about:Tooling and general case making
Posted 01 December 2013 - 10:14 AM
To do what you are talking about, you need to figure the length of zipper tape you need, add 1.5-2 inches evenly split on both ends. Remove the teeth that aren't needed. Meaning, if you need 10" of zipper, there should be 11.5-12" of tape with 10" of teeth in the middle of it.
With the tape separated, sew each half on to each of the gussets. Depending on the shape of the case, you might want to install the slides and stops now, or it might be easier to sew your gussets onto the case first, you'll need to figure that out for the case you're making. To be blunt, sewing the gussets on is the hardest part of making that type of case.
But a separating zipper is just a regular zipper with 2 slides started from each end going towards the middle, then you install the stops to keep the sliders from coming off. To hold the zipper tape to the leather for sewing, you can rubber cement it, staple it, or use double stick tape. I use the tape as it's a lot quicker and cleaner.
Hope this makes sense.
Chuck
Chuck Fields
fieldsleatherworks.com
#3 JLSleather
JLSleather
    Leatherworker.net Regular
  • PipPipPipPip
  • 2,255 posts
  • Gender:Male
  • Interests:My babies, leathercraft, fishin'
  • Leatherwork Specialty:carving
  • Interested in learning about:suppliers
  • How did you find leatherworker.net?:search engine
Posted 01 December 2013 - 11:55 AM
That zipper is stitched to vegetable tanned leather "gussets", which are then attached to the case. Not sure the reason for "multi-directional" on a case this small. I think the 'norm' with this type of case is a zippper running the length with a hole in the pull large enough to fit a lock, and a "dee" or sqare ring on the end that the lock attaches to when it's closed.
As for the actual constructing of the gussets, absolutely check out Stohlmans book on leather cases. The cases shown are largely outdated now, but the principles are still used. The style you are looking for are clearly outlined in the book cover, notebook, and briefcase (variations at each).
Purchase at store or download here.
FREE holster patterns  *  MORE holster patterns
Observation is 9/10 of the law
#4 xlr8tn
xlr8tn
    Member
  • PipPip
  • 114 posts
Posted 01 December 2013 - 12:22 PM
Excellent...thanks for the information...learned something new today - gussets.
#5 xlr8tn
xlr8tn
    Member
  • PipPip
  • 114 posts
Posted 10 December 2013 - 09:04 AM
Just finished up my gussets and trimmed edges to provide the proper gap on my case. I removed about an inch of teeth on my zipper on each end and installed metal clamp to prevent zipper from undoing. Can someone explain how to me how to sew each end to my case? I was planning to go about an inch on each side along the spline so I can open my case an lay flat.
-Brent
Edited by xlr8tn, 10 December 2013 - 09:10 AM.
#6 northmount
northmount
  • PipPipPipPip
  • 1,968 posts
  • Gender:Male
  • Interests:Jack of all trades, master of none.
Posted 10 December 2013 - 01:05 PM
The gusset needs about 2" extra length on both ends (4" total). Mark the gusset at the mid point on each side. Unzip it. Mark the mid point on each side of the case. Use seem tape or contact cement and start attaching the gusset at the mid point on each side of the case. Work towards both ends. If your case is going to be 1.5" thick at the spine, keep that space clear on the case material, and bring your gusset/zipper down inside the case. Don't sew or glue the piece that goes down inside the spine. All glued in place, punch and lace, or sew it together. Don't sew the gusset piece in the spine.
Tom
edit ... thicker cases require longer gusset/zipper to be able to open flat.
Edited by northmount, 10 December 2013 - 01:05 PM.
#7 xlr8tn
xlr8tn
    Member
  • PipPip
  • 114 posts
Posted 12 December 2013 - 08:33 PM
Here is what I came up with. Thanks for all the help. Last thing I am going to add is a d-ring so I can lock the bag and glue in the sherpa material.
Attached File  photo 1(1).JPG   121.46KB   64 downloads
Attached File  photo 2.JPG   115.33KB   86 downloads
Attached File  photo 3.JPG   157.15KB   68 downloads
#8 RiverCity
RiverCity
    Member
  • PipPip
  • 240 posts
  • Gender:Male
Posted 12 December 2013 - 09:17 PM
Looks good!
Chuck
Chuck Fields
Similar Topics Collapse
0 user(s) are reading this topic
0 members, 0 guests, 0 anonymous users
