  • entries
    28
  • comment
    1
  • views
    12,309
The Way to Destroy Flying X-4 Stormwing Plane in Fortnite
fortnite-destroy-an-x-4-stormwing-plane.
We're nearing the end of Season 7 of Fortnite, but Epic still has plenty of challenges in store for players before Season 8 arrives, and one of the requires players to destroy an X-4 Stormwing plane while it's still flying in the air.
The challenge that requires players to destroy an X-4 Stormwing plane a new, controversial addition to the game this season and some are having a bit of trouble with it, even if you only have to blow up just one.
Luckily, there's a relatively straightforward technique to do that because of the wording if the challenge. You do not have to kill an individual in a plane, you need to just destroy a flying plane. That implies nobody essentially has to be inside it, though it does must be airborne.
You're going to want two tools for this to function:
  • A plane
  • Some kind of midrange weapon, preferably something like a burst AR
You will find planes all over the map, but of course, Frosty Flights is your greatest bet, given that it's literally an airbase. But if you want anything that is a bit more isolated, head to one of the Expedition Outposts scattered around the map which also have planes outside most of the time. I produced a map of those yesterday since going to them all also happens to become a challenge this week.
So, what's the process right here? It's somewhat janky and demands a minimum of 4 seconds of moderate aiming talent.
Beat the plane to inside an inch of its life, as in, down to 60 HP or so out of its 800 total. This will take somewhat though since you may only hack 20 off at a time, so make sure you are alone.
Get in the broken plane and take off
Bailout of the plane when you are on an upswing. This could be appropriate right after you take off, or you could dive down then back up once again then bail any time. Do it sooner as opposed to later for the reason that if any individual requires a potshot at you, they're gonna get their plane-killing challenge.
When you finally bail out of the plane, land as immediately as possible around the nearest surface. Take aim together with your hopefully ranged-enough weapon and shoot the last remaining HP out with the plane which really should nevertheless be airborne at this point in the event you have been heading up after you got out. Gravity will only let for perhaps 4-5 seconds of time for you to shoot and kill it before it crashes on its personal, so aim true.
What are the Fortnite Week 7 Challenges?
Free Challenges:
  • Visit all Expedition Outposts (0/7). 5 Battle Stars
  • Use a rift or Rift-To-Go in different matches (0/3). 5 Battle Stars
  • Pistol Eliminations (0/3). 10 Battle Stars
Battle Pass Challenges:
  • Stage 1: Land at Salty Springs (0/5). 5 Battle Stars
  • Search Chests at Loot Lake or Frosty Flights (0/5). 5 Battle Stars
  • Destroy flying X-4 Stormwings (0/1). 10 Battle Stars
  • Stage 1: Damage opponents in a single match (0/200). 5 Battle Stars
Want to learn more fortnite news & guides? Welcome to visit U4GM.com. You can read not only fortnite tips but also buy cheap fortnite save the world weapons there.
0 Comments
You are posting as a guest. If you have an account, sign in now to post with your account.
