MADMAX22 Posted August 4, 2009 Report Posted August 4, 2009 Looking for some unwaxed linen thread for handsewing. I used the waxed stuff from springfeild and like it but trying to get the ends setup for for the needle is kind of a pain. I would like to play with some unwaxed stuff and use my own wax/resin mix on them if possible. I just havnt scene any suppliers of such. Thanks Quote
Cobra Steve Posted August 4, 2009 Report Posted August 4, 2009 Hi MADMAX22, try Dick Cizek (formerly of Rice Thread) at AH Brands. 1-803-684-7755. He will have it or he will know where to get it. Try him on his cell also 1-413-446-1686. Thanks, Steve Quote Thank You Steve Tayrien Leather Machine Co., Inc. 2141 E. Philadelphia St. Unit "U" Ontario, California 91761 1-866-962-9880 http://www.leathermachineco.com cobra@leathermachineco.com
Hilly Posted August 4, 2009 Report Posted August 4, 2009 You can find unwaxed linen thread here. Quote
MADMAX22 Posted August 5, 2009 Author Report Posted August 5, 2009 (edited) Thanks a bunch guys. I think Ill give that a go Hilly. I assume that barbours thread you can dye to get it different colors before you wax it, if so does the regular leather dye work or should I use like a RIT dye or something similer made for fabric? Edited August 5, 2009 by MADMAX22 Quote
Hilly Posted August 5, 2009 Report Posted August 5, 2009 Thanks a bunch guys. I think Ill give that a go Hilly. I assume that barbours thread you can dye to get it different colors before you wax it, if so does the regular leather dye work or should I use like a RIT dye or something similer made for fabric? I'd think it would be whatever floats your boat? Quote
Members Nate Posted November 23, 2009 Members Report Posted November 23, 2009 Looking for some unwaxed linen thread for handsewing. I used the waxed stuff from springfeild and like it but trying to get the ends setup for for the needle is kind of a pain. I would like to play with some unwaxed stuff and use my own wax/resin mix on them if possible. I just havnt scene any suppliers of such. Thanks You can find unwaxed linen here: http://www.campbell-bosworth.com/catalog/index.php/cPath/6_71_73?osCsid=6funrp8ns28q5o8mgjeut4ef76 Nate Quote
Members ChuckBurrows Posted November 24, 2009 Members Report Posted November 24, 2009 Thanks a bunch guys. I think Ill give that a go Hilly. I assume that barbours thread you can dye to get it different colors before you wax it, if so does the regular leather dye work or should I use like a RIT dye or something similer made for fabric? I use regular leather dye to color it - cut off what ever you need, soak it in the dye for a few minutes, as you pull it out use a cloth to pull it through to get rid of the excess. Let dry and wax,,,,,,,,, Quote Wild Rose Trading Company Two roads diverged in a wood, and I, I took the one less traveled by, And that has made all the difference.
MADMAX22 Posted November 24, 2009 Author Report Posted November 24, 2009 Since this thread started I did end up picking up some of the barbours thread (6 cord). I also got myself some rosin and made a rosin bees wax mix to use. Must say it is a great combo. No more of the ultra waxy stuff that you get prewaxed and the rosin wax mix is a joy to work with. It is just sticky enough to hold everything good and tight when you pull it. The thread lays wonderfully as well. Im finding it hard to use up my prewaxed stuff that I have quiet a bit left of. To anyone that hand sews this is definatly the way to go. A little more time involved but well worth it. Thanks Chuck for the suggestion. Ive started dyeing some of the stuff and it turns out pretty good. Pretty much do exactly what you suggest. Quote
Hilly Posted November 24, 2009 Report Posted November 24, 2009 (edited) Since this thread started I did end up picking up some of the barbours thread (6 cord). I also got myself some rosin and made a rosin bees wax mix to use. Must say it is a great combo. No more of the ultra waxy stuff that you get prewaxed and the rosin wax mix is a joy to work with. It is just sticky enough to hold everything good and tight when you pull it. The thread lays wonderfully as well. Im finding it hard to use up my prewaxed stuff that I have quiet a bit left of. To anyone that hand sews this is definatly the way to go. A little more time involved but well worth it. Thanks Chuck for the suggestion. Ive started dyeing some of the stuff and it turns out pretty good. Pretty much do exactly what you suggest. If you don't like how overwaxed the prewaxed thread is, try taking a piece of heavy brown paper, fold it over the tread, and rub back and forth very briskly. It melts the wax with the friction, allowing it to penetrate deeper into the thread while removing the excess at the same time. Makes prewaxed thread much easier to work with. Edited November 24, 2009 by Hilly Quote
Members Saddlebag Posted November 26, 2009 Members Report Posted November 26, 2009 I usually use saddleweight thread for handstitching, unwaxed, polyester and I like how it looks and works up. But then I'm doing mostly horse tack. I love the tips tho and at least will know what to do should the need arise. Thanks Quote
Members CliffFendley Posted December 18, 2009 Members Report Posted December 18, 2009 I'll vouch for the Barbours linen thread also. I use in on almost all my gun rigs. Quote http://www.fendleyknives.com/
