MAK67
Everything posted by MAK67
  1. Thanks
  2. I was looking for a sewing machine to sew wallets and bags and came across a Adler 269-373 for sale. The documentation I found indicates this model will be suitable for my needs. My question is does anyone know if this is a good design from Adler or did it have issues. I haven’t found much in the way of videos good or bad, I couldn’t find anything for setup or troubleshooting for it. My experience is with Juki clones so I am use to finding videos quickly and easily any time I have had issues to help me. The lack of videos and information is giving me pause and making me rethink the possibility of purchasing it. Does anyone have info or links to websites I may not be seeing. I did find a couple of videos, but I believe they were speaking German so I didn’t get much out of watching them. Any help or suggestions would be greatly appreciated. Thanks
  3. We are about 120 miles from the closest Tandy store, and it is the closest leather store to us. I may have to take a drive up there and check them out. I appreciate the help.
  4. I have been making belts for years using an oval punch to put the small holes opposite the buckle end of the belt. I am looking to have a die built to click them out. The punch I am using is a very old one that does not have the size on it, so I am not sure what size to tell a die maker to use. I make 8 oz to 16 oz belts so the oval holes sort of works well for that range. Since I am not sure what size to advise the die maker, I thought I would ask to see what size other folks that build belts use? Any help would be appreciated. Thanks
  5. Good job, Love the carving!
  6. I highly recommend Acetal Copolymer Plastic Sheet it is the best surface I have ever seen to not dull your blade or roll your edge and hold up for years. It is a little pricey but the time it saves by not having to sharpen or replace blades is worth it to me. Here is a YouTube video of a guy that does an excellent job of testing multiple cutting surfaces and comes to the same conclusion I have about this product. I hope this helps. Best Leathercraft Cutting Surface? What I Chose & Why (youtube.com)
  7. I have been digging into the differences between Cobra Class 4 and Cowboy CB4500 to determine what machine is the best value for me. The Cobra Class 4 and the Cowboy CB4500 and the Juki 441 heads are made in the same factory on the same assembly line. They are identical in every way until the Cobra gets painted brown and the Cowboy gets painted tan. Cowboy has stepped up in my opinion with the addition of the Stainless-Steel presser feet and needle plates to eliminate the possibility of rust due to the moisture in the leather, the Extra-Large Flywheel, the Wax/Lube pot for the thread and a Better LED Light. Cowboy also has a bit Heavier Built Speed Reducer. All of that is not included with the Cobra. I contacted Cobra they did not contest what Cowboy had told me, all Cobra would say is Cobra has a limited lifetime warranty, but Cowboy also has a limited lifetime warranty, so Cobra did now win any points from me on that. They both come with a heavy built table/stand and a Servo motor. They are both around $2900. I have spoken with Ryan at Neal Saddlery and Teleto Bob at Teleto industrial sewing, about the cowboy machines I also contacted Aron at Makers Leather, Heather Bradt at Leather Machine Co about the Cobra Class 4. This is the accumulation of the information I received from all of them. My conclusion is both are good machines but, it appears you get more for your money with Cowboy.
