Jan236
Everything posted by Jan236
  1. That looks really nice!
  2. So I've had this Al Stohlman maul for years and I like it for tooling, but the head has started spinning around and that pretty much makes it unusable. The thing wasn't cheap and I do like it so I decided to fix it. When I took it apart I saw that the head is held only by a friction fit with the nut at the bottom of the handle putting pressure on the top medallion and the metal piece under the head. I came up with an idea for pinning the shaft of the tool with a 5/32" tension pin. I did this near the top medallion, just under it. I then used the 5/32 drill to make several holes in the head to make a mortise for the pin to fit down into, locking the shaft to one position within the head. Making the mortise was kind of a pain and I had to finish it with a 1/4" wood chisel. I replaced the big nut at the bottom with a different kind and got rid of the annoying lock washer. It's all together now and that head will never spin again. It has a couple places where you can see the ends of the mortise that I cut on either side of the top medallion but I don't care about that.
  3. I know this is an old thread but I'm responding in case someone else has the same trouble. I took mine apart because the head was spinning around and it was unusable in that state. The head is held by friction only. I'm going to drill the shaft up near the top cap and put a tension pin through it, and then cut a groove into the head for the pin to slide down into when the head is fitted onto the shaft. The pin will stop the rotation.
  4. Very cool! I love making tools to use myself. Ive been thinking about making one of these.
