crossvillepappy
Everything posted by crossvillepappy
  1. Go to appliance junk or used parts place .Find fridge with movable glass shelves,and check that shelf brackets are higher on back side where it attaches to fridge.When you set this unit on a level table top it will be lower in front and higher by an inch or so in back which gives the tilt to the glass sheif.I used a cheap adustable desk lamp that I articulated so as light shined under shelf from back.The glass on my shelf is marked tempered so you won't have large shards in case of breakage.Also get a smooth glass ,some are a litte rippled
  2. You can purchase an inlay router bushing set for wood.You would route out table top and piece of thin good grade plywood to fit it.This is done by adding or removing bushing that allows for bit thickness and they will fit perfectley together.Take plywood disk and use it to cut leather or glue leather to disk.These router inlay sets are sold in better woodworking stores. crossvillepappy
