Missouri Mule
  • Content Count
    7
Everything posted by Missouri Mule
  1. I have a use for culled or trimmed out Brands from hides. Any finish or thickness. I need them at least 1 sq.ft. Thanks
  2. The only part I can help you with may be the stitch numbers. There are two 1/2" holes on the front of the machine. Look inside the upper hole. Inside that hole you will see the numbers on a wheel. You need adequate lighting to see them. Doug
  3. Wiz, I got the SEWPRO 500GR motor from Bob. I needed a 3" shorter belt like you did on your National. I played with it empty for a while. I feel much, much, more in control. It will be SWEET! Doug
  4. I think I found it. Singer 240148H and 240149H. Doug
  5. Thank you so much guys. I found most of them. I just got a 1/8" edge guide foot set, a standard foot set, and ordered a 3/16" guide foot set, and left toe set, . That's a start. Binding foot is next. It might be a while before I am ready for the welting and zipper sets. All I know how to do right now is get the thread from the spool and bobbin to the needle. Do you know where can I find the extra wide double toe? Thanks again, Doug
  6. I just bought an old, bare bones, Consew 226 and need to buy feet for it. The only sewing I have ever done was on the day I bought it , with the seller coaching me on it's operation . I am in the process of shopping the myriad of supplies needed, just starting out from zero. What are the most important feet or sets to buy for this machine? I plan on nothing thicker than tooled belts, suspenders, and probably some boat cover/tarp type projects. What attachments do you 111 clone users use the most? Thanks, Doug
  7. Hello all. Great site! I am a Newbie to leather working, soaking up as much as I can. I have read many of the recommended machine topics and have learned a lot. (My wish list may spin out of control. ) I ran across this old machine and would like to hear some opinions about it. Of note to me is it uses a 1/2 hp motor, large bobbin, and 135x9 needles up to #22. Singer 107w5 Manual Thanks
