ZARDOZ the GREAT
Everything posted by ZARDOZ the GREAT
  1. I opened them up. stitched the loops, and resewed them. Just went ahead and bit the bullet and got it done. Thank you all for the help and inspiration!
  2. Another thing I can do is only split them open enough to access the stitching of the belt loops. Once done, I can then start sewing again and, as I get close to the old stitch, finish removing those and continue.
  3. Yeah. I'm gonna give it a day or two. Just too frustrating to correct right now. I have Weldwood and have also used Barge. Both good. Just working in my living room right now and stench is a bit much. I sewed them by hand. Thanks.
  4. Great advice and information!!! Thank you all! Cutting them open and using pins to align the holes it shall be! Thank you!
  5. How-DEEEE-AMIT!!! So I was doing several things at once, packing, working on several holsters, a flintlock... over several days. I wound up sewing these two holsters up and applying some neatsfoot oil, then some Aussie conditioner... then I noticed that I never sewed the belt strap/loop!!! It's only glued on. The holsters are glued at the edges with SLC Ever-Tack. This is water soluble glue, so not a big problem. However, I am concerned that, once I cut them open and then go to re-stitch them, it will be a big problem aligning the holes again for the stitching. The leather piece with the spots that goes between each side of the holsters makes it more complicated to align. Considering using rivets to secure the belt/loop/strap. I think I can do this by using a narrow strip of steel on the inside as a surface to hammer on them/ I could also use Chicago Screws. Figure I'd have to glue a piece of pig skin over these on the inside to protect the pistols. Any ideas? Is it better to just cut them open and restitch afterwards? I am leaning towards that as I write this, but figure someone here with far more experience may have a more educated and effective suggestion. Just thought that when gluing them back together to prepare for stitching, I can run a bunch of needles through the holes, to make sure they align. Thanks.
  6. Great! Thank you! Love that color! British Tan? I love British Tan and Burgundy! Been trying to get a lighter burgundy. Thinned mine to 50% and still dark, so I will try thinned to 25%. Again, Thank you!
  7. How-DEE! I have a piece of suede in a beautiful rust red/orange that I am thinking of using to make a pair of gunbelts from, carried in a sort of "X" on the hips, like Curly Bill in Tombstone... Any advice on this? Will folding it over and sewing the edge like a regular money belt be enough? I am thinking of a 2.5" belt, so I figure a 5" wide strip for each, folded in half lengthwise. Any advice on doing the cartridge loops? The belt tongue/buckle part? I do the punched hole versions, but I don't think suede will be stiff enough for that, so seems either I would have to do sewn loops, or attach a piece of regular leather with the loops on it. The suede is about 1/8 in thick, so folding it and sewing the edge, I would think, would make a pretty strong gun-belt. I also have some car upholstery leather (seems like real leather with a rubberized coating of some kind) that's about 1/16" thick which I could use on the inside, but I think this would make it unnecessarily thick. Thanks in advance.
  8. Good points all around!
  9. Thank you everyone. I will try and figure it out. I got some of those thin green wires used for floral crap and will see if that will work. I have some spare bobbins and that threader wire in storage somewhere, so maybe it will pop up next time I go.
  10. I can't find the wire used for running the thread down to the needle, or the bobbin holder to refill the bobbin. I also am trying to figure out what thread the bottom holes have to attach to a table, but I figure that may be trial and error. Any suggestions on alternatives/hacks?
  11. I also read saying it is a copy oif a "Consew".
  12. Oh wow! Thank you! So it's a copy of that Singer. Thanks!
  13. HOW-DEE! Does anyone have instructions/input on how to thread and use this machine? It's a copy of an original one I think. Has the hand crank but I also have the electric motor kit. I want to learn how to set it up and use it, but can't find instructions. Thank you!
  14. AH!!!!! Thank you!
  15. I don't understand that. Is there a drawing? Photo? I make most of the cowboy cartridge belts at 2.5" wide. 3" is also an option. What I am trying to be sure of is the length. I have read that it is best to take the measurement for the belt as it would be worn, then add 9" to allow for overlap which goes underneath the buckle side.
  16. HOW-DEE... Question It's been a bit and I want to be sure that I am doing this right: For a cartridge belt (old west), we measure around where the belt will be worn, with the proper clothing, then add 9", correct? This means that for someone who measures 46", I would cut a 55" strip, with the 9" being the tongue that goes under the belt overlap. Or is there a better way? Thanks!
  17. Here's a question: I have a couple of big pieces of upholstery leather; the kind used for car seats. I was given it by an ex girlfriend who worked at a major car manufacturer. This has some kind of coating on it to protect it. Do you think this wold be suitable for a lining-especially for a belt, maybe with the rough side out? Or maybe not worth it, as the leather for the belts and holsters I am using is 9-10 oz.
  18. Ah! Your idea of using two layers of thinner leather is a different thing. I was looking at two layers of 9 and that seemed too much, but two layer of 5 or 6 would different then. Maybe I can try a belt using what I already have : 9 oz leather, with like a 3 oz liner. I started making the belts in a slight crescent by wetting the blank and then putting it into a plywood "notch" sort of to dry. This has been only one so far, single layer, 9/10 oz and it has held up according to the wearer. I will continue doing it this way as it seems to work. On that belt I added the bullet loops afterwards using another narrower piece of leather and the loops were canvas. However, I will be making three belts soon for one person, and I think cutting the bullet loop holes and also adding the loops before the belt is wet shaped will be much easier and better. I think doing the shaping with empty cases in the loops will be best.
  19. Good points. The belt is for Cowboy action shooting. And I see your point: when I have carried something like a 1911, a soft belt is just awful with the sagging. Makes it feel much heavier. But with a cowboy belt, a 9 oz, 2.5" belt seems to handle the load much better for me, especially with the holster and pistol riding lower than a 1911 (in a modern setup). I may have to make one line to see how it compares to unlined. Thank you!
  20. How-DEE! I tried searching but no luck. Regarding western gun-belts (authentic style, not buscadero), How many of you line them and how many don't? Why/Why not? Is there a benefit to lining that outweighs the added thickness/expense/labor? If you line, do you use the same thickness leather? Smooth or rough side out? Anyone ever line with something like thick canvas, felt? Seems to me that lining adds thickness which can be good, but also stiffness, which seems to prevent the belt conforming to the wearer, not to mention adding weight, which is a negative, especially when you add one or two pistols and the ammunition. Lining with the smooth side out seems to contribute to the belt sliding down or up easier. Lining with the rough side out seems to be no different than not lining, and adds extra weight and stiffness. As nice as lined belts may look, it seems to me that there are more negatives than positives. Same with holsters. I would like to read the opinions of more experienced makers. Thank you.
  21. What about just a mixture of bee's wax and olive oil, in a paste? There's also the Aussie stuff that seems to be the same, in a paste. Seems like this would be simple, smell good, and protect the leather. without any plastic feel etc. Yeah, maybe not as permanent as the other stuff, but what's so difficult about redoing it once a month or even once a week if there is bad weather?
  22. The Bianchi method seems valid, though I have owned two Bianchi cartridge belts that had no curve. That being said... did Bianchi ever explain cutting the cartridge loops on a curved belt? Unless it' as simple as cutting and adding the loops and then giving the curve by wetting and forming the belt...
