david116
Everything posted by david116
  1. Yes,everyone Happy New Year!
  2. Hi,Anthony, how about this,see the attachment. Technical Parameter: 1.Gilding area:210*290mm 2.Area of the worktable :400mm*320mm 3.Max. pressure:4000Kg 4. Up and down throw:40mm (Can be increased to 80mm) 5.Power of heating :1000W(According to gilding area) 6.Paper feeding method: Motor driven 7.Temperature range: Room temperature -300°C Product advantage: 1. Electric controlled operation. 2.Heating temperature is stabilized by temperature controller. 3.Vertical pressure crankshaft design which gives powerful pressing force. 4.Adjustable hot stamping pressure, temperature and speed; 5. Multi-orientation and angle adjustment of the worktable. 6.Adjustable automatic paper feeding and receiving. 7.Photoelectric celled can be installed for pitch control according to requirement. 8.Worktable height can be adjusted freely. Product description: The workpiece is loaded and unloaded manually. Full automatic processing; steel plate base, smooth gilding process; vertical pressing force; it can realize gilding, impressing and embossing of paper, plastic, leather, PVC and wood products.
  3. Hi,jdwintx you have a good idea,maybe i can do business with you, some of hardware factory beside me. but you need give me products picture,so that i can find the correct products. my family factory is a metal products company, we don't supply what you want,but i know who produce.
