BigJake
Content Count
50 -
Posts posted by BigJake
Somehow I thought the 3200 was the larger machine. After checking the website I see it's not. My comments were more towards the 3500 machine or the Juki 441 clones. I have the Cobra 4-P which came with the three plates, and roller edge guide. Good luck with your new machine.
Chief, Did you get the several plates, feed dogs, and edge guide with your machine? Does yours have the servo motor? I bought the Cobra Deluxe machine around the end of last year and it came with the three plates, feed dogs and edge quide and I never use the edge guide. I do use the holster plate most of the time and the standard plate for really thick stitching. Most of my work is cowboy gun leather, in fact all of it. I have found the holster plate works best for general stitching except for the main seam, which is too thick to fit under the pressor foot.
I always use a guide for belts but the roller guide which came with the machine does not work well for that. I fabricated a guide which fits in the roller guide bracket and lets me run the guide right up to the edge of the pressor foot, which means less than 1/4 inch from the edge, stitch line. I also use 277 lubricated nylon thread top and bottom because I like the look of the larger thread. When I go from a single layer of 6/7 veg tan to 1/2" or more thickness I adjust the top tension knob about two turns for the thinner stuff and no adjustments to the bobbin tension ever. I also ground off the bottom of the needle foot to get rid of the ridge which is suposed to bury the stitch below the surface of the leather. This is supposed to make the stitch look better, I suppose, but created more problems than it was worth. I just increased the bobbin tension a bit and the top tension to pull the thread a bit tighter in the stitch.
You may have a short learning curve coming from a Boss but you at least have the concept of stitch tension understood. My transition to a Cobra was relatively short as I came from an upholstery background using a Consew 206RB5. Good luck and if I can help in any way please let me know.
Mungo,
Mine are 4x and that's about right for me for carving, gunstock checkering. etc. Mine came from Enco about 20 years ago so I don't know if they still carry them.
I've learned how to work with it and what to expect once it dries. It sure does pick up some dye..so just working with it and trying different applications was what helped me. I really like how it proctects the product and up to now I can't seem to find another finisher that can do the same. I've been looking for the same protection but with a lower sheen.
BigJake... how does that angleus satin sheen work for you...? how does it held up to water?
The Angelus Satin Sheen holds up as well as Resolene as both are water resistant and not water proof. Having said that, keep in mind that my leatherwork efforts are confined to cowboy gun leather and as such are not generally exposed to inclement weather. Saddle bags, motorcycle bags, and items that would be exposed to rain and such.......I have no knowledge of.
As for the gloss, the Angelus Satin Sheen is just that within limits and the number of coats applied. Spraying versus sponge application will result in a higher gloss as a general rule in my experience. Most of my cowboy holsters have a flap over the top of the belt and extends down to the bottom of the holster. The back-side of this flap gets three coats of spray applied Satin Sheen for added protection from sweat from the leg of the wearer. Satin Sheen also makes a fine resist when using antique paste.
Let me add that when applying acrylic products using spray equipment, proper cleaning is essential. By that I mean, dis-assemble the gun and clean all the parts in the fluid path otherwise clogging will soon become an issue for you. The vinegar and household cleaner mixture will disolve the hardened acrylic if your gun does become clogged and I have not found that denatured alcohol will do that. In my experience, denatured alcohol works about as well as tap water.
I have a supply of automotive paint strainers used for automotive paint, not the kind you might get from Home Depot. All my acrylic topcoats are strained when it goes my paint gun cup, for the simple reason that any clumps or contaniments in the acrylic will clog the gun tip. I mix my Satin Sheen and keep the 50/50 mixture in a large jar so it's ready for use. Sometimes, clumps will occur in the mix or some of the dried material from the mouth of the jar will somehow get in the mix. As I said, I strain it everytime. Then there is the subject of spray guns which is a long discussion in itself, best left for another time.
In my experience, Resolene or any of the acrylic top coats don't work well when applied with a dauber or sponge. If my project is a small strap where I can apply the acrylic in a single pass and cover the entire piece, then it works OK. Larger projects, not so well. The acrylic seems to disolve the Fiebings Oil dye to a degree and the streaks are caused by that. While I must admit I don't use Resolene much anymore, I use other acrylic products like Angelus Satin Sheen, Mop & Glo, to name a few. These are all acrylic products and will have the same issues when applying with anything that touches the surface of the leather. In my opinion, the only predictable and satisfactory way to apply this type of top coat is by spraying. Most of my work is gun leather, holsters and gun belts, and these are what I would call small items as compared to saddle bags, brief cases, and such. For my projects an airbrush fills the bill perfectly for acrylic top coats as well as dying with Pro Oil dye and streaks are never an issue.
When using spray guns with acrylic, special cleaning is required otherwise the build-up of dryed acrylic will clog the tip. While the product is mostly water soluable, water only will not do a satisfactory job, even with detailed cleaning. There always seems to be a residual of dryed acrylic left in the gun unless one uses a mixture of vinegar, water and a general purpose household cleaner. This will cut the acrylic and leave your gun ready for use the next time you need it. I mix about 1/2 cup vinegar to 1/2 hag of tap water, and about 1/4 cup of Spic & Span liquid household cleaner. I use the Spic & Span because that what the Wife buys. Disassemble the gun and soak the parts for a few minutes in this solution, clean with a small brush, rinse well with tap water, blow dry and re-assemble.
I use the same spray guns when dying with Pro Oil and Denatured Alcohol cleans up everything nicely when I'm done. I hope this helps.
Any way we could see some good close ups of it?
Pretty good image in post #1 of this thread. Click on the link and zoom the image. Also a video.
When one is considering an edge and how sharp one over the other may be look at a straight razor and how the blade is cut and the long angle. Sharp is a long angle. Now the edge on an axe for example is very thick and the angle is short because the axe is used for chopping and not cutting and must be strong to withstand the forces of chopping. One cannot make the blade of an axe suitable for shaving because of the steep angle of the typical axe blade. Compare the blade of your round knife, is it thick? Is it 1/8" thick, no.... not any I have seen or own, more like 1/16" Sharp is the important factor and you cannot get that with a steep angle of the edge. Look at the edge of a wood plane, is it a steep angle? no it's not. A steep angle is for heavy abuse and heavy force. In my opinion a steep angle means more effort to pull the leather thru. I have a general purpose leather knife made by Osborne with about a 3/4" wide blade with the angle front to back of the blade. It cuts very well. Osborne made it that way.
A shallow angle cuts better than a steep angle pure and simple but your mileage may vary.
I have been doing research on which of the several splitters and skivers that were available would fill my needs. First I want to distinguish between a splitter and a skiver by my definition. A machine with no means to lock the blade adjustment without actually holding it in place with one hand is a skiver. A machine that allows one to lock the blade for a given thickness and then allow both hands to pull the leather thru is a splitter. I wanted a machine that would do both.
The blade on a splitter is of such critical importance that became my focus. The Heritage machine sold by Weaver caught my eye mainly because of the angle of the cutting edge which covered the entire width of the blade. The others machines I considered only had an angle of about half the width of the blade. I'll also add the blade is 1/2" thich at the rear and 1 7/8" in width. The bottom of the blade is flat. I removerd the blade thinking I could improve on it since I am very anal when it comes to a sharp tool. In fact my sharpening routine includes examining the edge with a 10x jewelers loupe. Close examination of the edge appeared to me to be buffed with a polishing wheel and/or stroped. I concluded I could not improve on the edge and reinstalled the blade.
My machinist background and with the measuring instruments I have I made a few checks for blade alignment and found it to be "Spot On" centered over the roller. I am fairly certain this machine is made in China although nothing indicates that on the machine or the packaging. It certainly appears to be a clone of the Osborne 84.
This tool must be bolted down to a substancial table or work bench and I only have veg tanned leather to test but I could pull 3" wide 12 oz thru the machine with one hand and no strain.
I am in no way connected to Weaver Leather other than a wholesale customer and I can honestly say, this machine does everything I needed and would most likely outlast me. I can recommend this 8" skiver without hesitation.
Here is more info:
Chief,
You can get a wider pattern with the Paasche airbrush with more air pressure. I use a #3 tip and 40 PSI when spraying oil dye of 50/50 acrylic top coat. This setup works well for dye but is lacking using Resolene or some of the other acrylic top coats. The issues I've experienced have become apparent on the second coat of acrylic top coat and any additional topcoats. The design of the Paasche does a poor job of atomizing. I use the #3 tip on the Paasche and those with a smaller tip may have a different experience. It's definitly workable but I recently purchased an Iwata airbrush and the atomization of the sprayed product is night and day different. Superior in every way because the design is totatly different than the Passche. The Iwata airbrush is a professional tool, no question and the only issue is the cost. You decide, but if I'm lying you can send some of your homeboys to pistol whip me.
It seems some are buying their edge finishing products at the Adults Only Store or the drug store. I ordered the real deal from Sheridan and just so you know, it says right on the bottle, "Quik Slik." So far in my testing, it looks like this may be my "Go To" edge dressing. I have a homemade power edge machine patterned after the Weaver machine. I have a wool felt drum and a wood drum that fits the machine and the Quik Slik seems to work best on the wood burnisher. The Quik Slik also accepts dye and Neat-Lac as a top coat and seems to keep everything slicked down during the process.
I use Resolene and it resists Fiebing's anitique paste great!!
+1
RS, This is the finish I use the most on my cowboy rigs. A 50/50 mix with water is just about right on Oil dyes or drum dyed rigs. If you can justify the cost I suggest using an airbrush to apply it. The Pasche is the most economical and works reasonable well with a #3 tip. The Cadilac air brush, in my opinion is the Iwata, but more bucks than the Pasche. Most of my rigs are custom dyed and I use the airbrush 100% of the time for that task.
I ordered a bundle of ten and could'nt be happier with the quality. I expect to order more in the future.
I have been researching skiver/splitters for awhile and educating myself in the process. There are several out there and since I wanted one that would both skive and split, which allowed me to narrow the field some what. My next consideration was a comparison of the blades of the several models which I could only do by careful examination of the photos available on the web. The Osborne 84 design and knock-off's of the same narrowed my search down to one. Used splitters were not considered due to the potential of blade damage from improper sharpening. The Campbell-Randall unit looked very good but was not in stock for at least six weeks. I finally settled on the Heritage skiver sold by Weaver Leather and ordered one yesterday.
What separated the Osborne 84 and clones from the others was simple the blade and the angle of the edge. The angle runs the entire width of the blade as opposed to half the width like the other tools. In my view this allows for a sharper and better cutting blade much like comparing the edge of an axe to a chefs knife. The proof, of course, will be in the testing once the tool arrives.
I try to match the size and breaking strength of the thread to the project. Plus, one has to choose a combination that conceals the lockstitch knots between the layers. So, here are some of my general recommendations for you.
- For very thin and/or soft projects, 3 - 5 ounces: #69 thread with a #18 needle (below 441 practical limit. Round point only.) (8 /inch)
- For thin projects, 6 - 8 ounces: #92 thread with a #19 or #20 needle (at practical bottom 441 limit. Round point only.) (7 /inch)
- For 9 - 12 ounces: #138 thread with a #23 needle (typical, consistent 441 bottom limit. Smallest leather point 794 needle) (6 /inch)
- For 13 - 20 ounces: #207 thread with a #24 needle (great for stitched belts, single and double leather) (5.5 /inch)
- For 21 - 28 ounces: #277 thread with a #25 needle (5 /inch)
- For 1/2" to 3/4": #346 thread with a #26 needle (4 /inch)
- Extra heavily stressed projects, 3/4" to 7/8": #415 thread, with a #27 needle. (3.5 to 4 /inch)
Exceptions
- Holsters, outside the pants, with security thumb-breaks: If at least 1/4 inch thick, use #277 thread, at 5 /inch. The knots can be buried inside the layers and the 44 pound thread breaking strength resists tearing during a struggle for the gun.
- Sam Browne duty belts, 1/4" to 5/16" should be sewn with #277 thread, at 5 /inch.
- Extra thick, double leather (over 3/8") professional weight lifter's belts should be double row stitched with #346 thread, at about 3.5 or 4 to the inch. These belts take a tremendous amount of stretching and abuse.
Stitches per inch
I use long enough stitches to look good on top without forming loops on the top or bottom when the project is bent (like a belt). Conversely, when the work calls for closer stitches, you have to make sure they don't perforate the stitch line.
Why?
"S" point needles, like the type 974 Schmetz makes for 441 clones, slice the leather with inline, wedge shaped cuts. This buries the ends of the thread inside the top grain and makes it appear like the stitches are closer together. If properly spaced, thick thread adds to the strength of the package. But, if placed too close, the holes in the leather weaken the package beyond the thread's ability to secure it. In fact, if the holes are so close that the thread is stronger than the leather between the holes, it can slice right through them. Also, the larger the diameter of the thread, the bigger the knots formed by the lockstitches.
When sewing with thick thread, like 207 and larger, space your stitches out to avoid slicing through the leather: e.g., no smaller than 6 to the inch. When sewing with #138 thread & 23 needle, you can go a little shorter, to 7/inch. If you use #69 or 92 thread, 8 to the inch is okay.
Thread breaking strength list
- #69 (T70): 11 pounds
- #92 (T90): ~16 pounds
- #138 (T135): 22 pounds
- #207 (T210): 32 pounds
- #277 (T270): 45 pounds
- #346 (T350): 53 pounds
- #415 (T400): 72 pounds
Wiz,
Great post and very useful info......thanks!
I buy all my spots from Standard Rivet Company found here: http://www.standardrivet.com/spots/round-spots/1-round-head-spot.php They have stainless and nickle plated brass along with the best tools for setting the spots. I use from 1/8" up to 3/8" and have their tools to set them. Trust me when I say setting round spots without a tool will make you quit leatherwork.
If the square foot cost is about the same as the double shoulders you're now buying, why not just stick with that. Some suggestions for the use of the belly that come to mind is Kydex lined holsters, knife sheaths, spur straps, to name a few. You recently post a pic of a shotgun belt which you made for RRR.....the copy of the Doc Knoper design. That belt would lend itself to belly leather. Another thought you may consider. Since you've indicated you're thinking of starting a leather craft business this year, buy some sides and give them a try as a "Startup Expense." Your accountant would know where to claim that on your Income Tax.
By the way, I only buy sides in saddle skirting thickness, 12 oz and above. Wickett & Craig will "Plate" any hide you order for a small extra charge. That will reduce the soft temper of the belly to some degree, but will certainly compress the fibers in the hide and improve the temper. Of coure you will not be able to inspect the hide before purchasing, they will send you whatever is on the top of the pile.
Since you are in the neighborhood of Zack White where you buy most of your leather, you have the advantage of looking and feeling the hide before purchasing. That gives you a tremendous advantage over most of us who have to purchase online and sight unseen. I to make gunleather and for the most part purchase from W&C, RJF Leather, Weaver, SLC, and only buy sides in saddle skirting in 13/15 and then there is more waste than I would like. If I had the luxury of picking my sides I would be a happy camper. By the way, I have enjoyed your many holsters and belts which you have posted pics on this forum........very good work.
You say you're using oil based dye and I assume that means Feibings Pro Oil Dye. All of the Feibings and Angelus solvent dyes use denatured alcohol as a reducer/solvent. Water based dye, of course use water for the reducer. Go to Home Depot or Lowes and buy a gal. of denatured alcohol for major savings over the same thing packaged under the Feibings label. Rinsing between colors is good practice, but a complete clean should be done at the end of the day. As for the cleaning when using acrylic based products such as Resolene and many others, you may find that cleaning during the day may be required. I usually close off the tip on my Badger air brush by screwing down the adjustment nozzle. This helps keep the tip from clogging since the acrylic sets up pretty quick. At the end of the day when using acrylic be sure to give your air brush a complete detail cleaning with water otherwise you will have problems in the near future with clogged nozzles.
I use a premix of 50/50 acrylic topcoat either Resoleen or Angelus Satin Sheen and water for my top coat and the shelf life is long on the mixture but you will save yourself some grief if you go by you local automotive paint stone and get some paint strainers which should be free or just about. I always strain my 50/50 mixture of acrylic when loading my airbrush bottle due to the lumps that can accumulate in the mix bottle which will clog the airbrush in a heartbeat.
All my gun leather is dyed using an airbrush and Feibings Pro Oil Dye, except for black which is dip dyed. My top coat of choice is Angelus Satin Sheen mixed 50/50.
I'd like to see some of your work, send a photobucket link or a link to Leatherworker Gallery, or send me a PM with a link.
I've seen "Quik Slick" mentioned here on this forum as an aid to edge finishing instead of saddle soap. I can't find this product at SLC or even using a Google search. Anyone know where I can find it?
Gump,
I may be off the mark here since you have much more experience than me, but I use the Pro Oil almost exclusively and generally do not dip dye. When making a black gun rig (belt and holster) I do use drum dyed 6/7 oz and laminate two layers for my holsters. For the belt and other parts I dip dye using Pro Oil black. I have found that some natural veg tanned hides do have a tendancy to "Gray" somewhat after dip dying. Even two dips does not correct the problem. Not all veg tan exibits this problem and I suspect it's all in the way the hide is tanned. I do not think the Pro Oil dye is the problem. A light coat of Neetsfoot oil takes care of the "Gray" and there is a good match between the drum dyed 6/7 and my dip dyed parts. You might try the neetsfoot oil. Hope this helps.
I have no experience with bull hide and I'm looking for some heavy weight tooling leather for gun belts. Something in the 12-13 oz range but tooling is a must as well as dying. How does bull Hide compare with regular Veg Tanned leather that one might get from W&C or RJF Leather? Is bull hide more firm? Texture of the grain side more coarse? I really don't want to buy a bend just to experiment so a little advice is needed. Thanks
I have used RJF for my last 4 or 5 purchases in assorted weights, double shoulders and bends in grade #1 and drum dyed veg tanned. All have been great, at a better price than W&C or SLC and better quality. Send Roger an email or call him and while he doesn't take credit cards, he will mail you an invoice for payment by check.
Dip Dyeing
in Dyes, Antiques, Stains, Glues, Waxes, Finishes and Conditioners.
Posted · Report reply
I have to chime in here and admit to being a user of RJF leather. In the beginning I only ordered veg tan and was satisfied with the product. Later I order some drum dyed black and was satisfied with that as well. My last order included an order for a medium brown drum dyed double back. When it arrived I was surprised to see that the flesh side had little or no dye at all and the penetration on the hair side was very minimal......like it had been sprayed. I called Roger and he stated it was in fact "Drum dyed" but not all the way thru. I'm still trying to figure out how that could be managed. Reqardless, I though I could still use it. I tried some scrap pieces using an arcylic sealer and it turned out OK. I'm thinking this would save some time in the holster making, so cut out a pair of holsters and a belt which would be a matching set. I ocassionally use a product sold by Weaver called Leather Firmer which is used in place of water during the wet forming. Never had a problem before with this product. So I dip the holsters in the leather firmer and some of the dye leached out in the chemical. Put the holsters out to dry with the pistols inside. The next day after partial drying they were almost chocolate brown, much darker than before diping. Again, no issues with this product when using natural veg tan leather. Now I had to try to match the belt to the holster color or use the leather firmer on the belt. I was able to match the color using a spray gun. The customer likes the rig even though it was darker than what he originally ordered.
My take on this and must be taken as my opinion only is RJF is dying the veg tan himself using a sprayer. He did mention to me in an earlier conversation that he had spent many hours in a spray booth dying leather........in his past. This was months before my issue with the med brown back. I think he still gets his product from Throughbred and their quality may have slipped a bit, even with the veg tanned. The opinion I now have is I will buy drum dyed black only from RJF and the browns from another source. As a side note, the black is dyed thru and thru and the Leather Firmer has no effect and the dye does not leach out.
