gecko nz
  • Content Count
    3
Everything posted by gecko nz
  1. in addition to the singer 132K manual available in this post, here are some links to Seiko and Consew manuals which give you more instructions and setting, the seiko/consew SK-6F is the equivalent of a 132k6 https://www.supsew.com/download/Seiko/Seiko SK-6, SK-6F, SKM-26 Instruction Manual.pdf https://www.consew.com/Files/112347/InstructionManuals/SK-6FR.pdf SK-6FR.pdf Seiko SK-6, SK-6F, SKM-26 Instruction Manual.pdf Files uploaded to LW.
  2. parts from the typical tw1-2b can be used on a 132k6, feed dog, needle plate, main tension assembly, needle bar, the same needle bar with clamp will also fit an adler 105-64 at a fraction of the adler price.
  3. if anyone is still interested in replacing the shuttle ring in a singer 45K i just replaced the hook/shuttle ring in a 45k-25 part number 91430 with a shuttle ring out of a Typical TW3-441 part number: 52WF1-032, drop in replacement, no grinding or modification required only difference is the original singer shuttle ring is 3.30mm thick the typical one is 3.50mm thick.
