yutaoy
Content Count
31 -
Calendar
Everything posted by yutaoy
hey, guys, I'm making watch strap, have been looking for tube to put on strap, can't find though. anyone sells it or know where to get? always thanks leatherworkers for help
pcox, you mean you have different bobbin case for different size thread, that sounds a good idea, then don't have to adjust bobbin case tension again and again.
tricky tricky! I lightened bottom robbin, now is better. so everytime when sew different fabric, need test. as mlapaglia said " It is a balance between the bottom and top. On my Boss I have a light bottom tension and then adjust the top until it pulls the two threads into the center of the hole." before yesterday i only knows that just need to adjust top tension, didn't know that also need to work on bottom robbin. first class after got my baby! Thank you guys! I love leatherworkers here!!!
that's cool guitar!!!
guys, is that stich right on the back of leather? still wondering if I did something wrong.
Thank you dirtclod, just tired loosen the top tension, almost no tension, is little bit better, but still can see " front top thread " on back stich. is stich should be like this on back? or should look same as front stich? nice and neat. I think on back stich should not see " front thread " , right? maybe I'm wrong ... m.. I using top thread #69, robbin thread # 69.
gusy, I start to practice sewing now. I got a question: yesterday I sewed with 138 thread on leather, stich on front and back both look nice. today I bought 69 thread, changed needle to #20 as pfaff manual says, tighted tention ( is tightest already!) but back side stich looks not good, see the brown thread on picture, can see grey thread ( is top tread ), top tention is already tightest, where is not right?
Ash, you have newer 1245 or pfaff 1245-706? is your stich not straight sometimes?
I tired both presser lifter this weekend, think both good. and Wiz, 8 foot pedals and 9 knee levers! my god! ^.^
I got the machine! Wiz! love it! should get new thread, got old thread from nice owner, always stuck and broke. Wiz, this pfaff 1245 have nice stich, when owner showing me + sewing by myself, stich was beautiful and STRAIGHT. tonight I tried on soft leather, stich was not straight sometimes. is because I didn't hold leather right? or ... this afternoon when I test at owner's place, we tried vege tanned leather/heavy thread, was really beautiful and straight. I wondering why I tried on soft leather tonight and stich was not straight sometimes. mmm... also Do I have always to adjust tention when I change fabric/when add more layers? about stich lenght, is "thinner fabric narrower stich length? thicker fabric wider stich length"? pfaff 1245 Needle Size Information: #207 top thread and #138 Bobbin thread use a #23/160 needle #138 top thread and #138 Bobbin thread use a #22/140 needle #92 top thread and a #92 or #69 bobbin thread use a #21/120 needle #69 top thread and a #69 bobbin thread use a #20/110 needle think I will not use thread over 207, but can I use thread under 69? So happy and really thank you guys here for helping me all the time
Thank you Wiz This is pfaff 1245 machine, on the reverse place has number from 0 - 6 mm for stich length, it means the longest stich of this machine only can go 6mm ... ? seller said will adjust the stich length, I will I go test again. try if can sew 5 stiches per inch. should I ask him to adjust to 10mm as longest stich length?
Wiz, I went to try this machine at noon time, it looks 80-85% new, I think is in good condition, but not quite sure since I only know little bit about sewing machine. I didn't buy it, three reasons, seller will do it for me in this two days. 1. servo motor, he's going to put consew 3/4 servo motor for me ( will tell him to demonstrate it running at 1 stitch per second ). he asked me if I want to get "something" for needle, let me explain if I understand what he meant. this " thing " will help to lift up needle, don't have to wind machine wheel ( the wheel for belt ) to lift needle up. he will put it on wheel. if want to have it, pay 30 bucks more. do I need it? is it good to have? Wiz and guys. 2. important! this pfaff has reverse also can adjust stich length, reverse works good. but stich length, ok, this is what I did. there are 7 numbers for stich length, 0, 1, 2, 3, 4, 5, 6. I put at 6, is not so long, seller is really a good guy, he brought the stich length disc and measured the stich length on leather, is about 4.5 wide, not really 6mm. then I tried to put at 4, stich length on leather is shorter. then I wanted to push to 3, 2, 1, but that stick can't go up to 3,2,1,0. so means now this machine only has 2 size of stich length, 6 ( acturally is 4.5mm ) and 4 ( I didn't measure if stich on leather is really 4mm ). seller said he will adjust stich length for me, can't push up to 3, 2, 1 is because that nut is not smooth. I attached photo here, might help you to understand what I said. ( bad english, ehhh ) I think have good/right stich length is important, do you guys think so too? cause if sew thick stuff like leather, we need long stich length, right. if sew thin fabric, we need short stich leagth. so to me, correct stich length is important. you guys also will test/measure to see if stich length is right? 3. extra basic things, seller will give robbin, needles, foot, thread. what else things can I ask to have since he might have/give? ok, I keep searching/studying online, always thank you guys for help
Thank you Wiz and Tom! so much so much! I really learned a lot from you guys here! Yes, I went to try this machine today, is foot lift pedal (shoe shaped) is hooked up to the lifter arm on the back of the machine. and is good to hear from Tom about it, I saw a lot knee level lift, so naturally thinks knees level lift maybe better than foot lifter. Will ask more question in another thread now.
Thank you guys for your reply, the machine I'm going to try doesn't have knee level to presser foot, but has a " shoe shaped pedal", is shoe shaped pedal also for lift presser foot? mm, I think answer is yes cause Spinner and studioN said. just wondering do I need to change it to knee level lifter? I attached photo here.
Thank you Wizcrafts! always always I'm going to try a pfaff machine this noon, seller said is 3/4 horsepower consew servo motor, is it good or good enough for sewing leather? which one should I get? since servo has different type, ( is a 1245 machine. )
Thank you guys for replied, really appreciate another question: seems that robbin winder is good to have. right. but should I change presser foot lifter? or is ok to use, cause I saw most of machines use different presser foot lifter.
Thanks for your reply! Tom. I just called the seller, he said he will change clutch to servo motor for me. the servo motor is 3/4 consew one, he said something horse power like you said. is it good one to have? even he explained to me, i still have no idea which one he means, only know: A. is consew servo motor. B. is not 1/2, is 3/4. C: horse power something.
yes, I have not get a sewing machine yet, after long time, still have lots I don't know about heavy duty sewing machine. I saw 2 pfaff machines, one with servo ( you can see has speed number on the motor, start from 0 ), another one with clutch motor ( if change to consew servo motor, then this two machine price are same, but consew servo motor has different too! like 1/2, 3/4 or maybe more ). now I'm confusing about servo motor, don't know which one is better ( since two pfaff both are in good condition), which one i should get? help!!!
another question: I saw this machine has two pedals, that's right pedal for?
Hi leather guys! what is this wheel for ( right side ), I saw some machines has it, some don't have it? Thank you always! is it for windding thread on robbin?
a, i c! Thank you Rob! is newest consew made in China instead of Japan? ... and 1. if I don't change to servo motor now for 206 ( can't afford that now, ehhh... ), there is anyway to control speed? can go slow? is presser can control? 2. how much bucks different between -2 and -5 around/usually ( used ).
also, can adjust Stitch Length? and how much different between -2 and -5 usually?
Andew and Ron, Thank you guys so much! I will check everything that you guys said: 1. clean, no rust. 2. will bring leather to test, see if stitches are evenly spaced. 3. any extra stuff like presser feet and needles with the machine. I still can't decide which one should get since they are both work on leather stuff... question: 1. if I don't change to servo motor now for 206 ( can't afford that now, ehhh... ), there is anyway to control speed? can go slow? is presser can control? 2. there are two consew 206rb I found, one is -2, another one i'm not sure is 5 or ..., price is just 50 bucks different. so which one is better? I attatched photos here. Really really Thank you guys! man, really don't know how to get a right machine without leatherworker, you guys are very nice and great!
Hi guys! a consew 206rb is selling online, I'm going to take a look first. my question is what should I ask? like get to know about its motor ( seller said is clutch ) .. is all I know what to ask, really new newbie here, eh. I will go with my mom, she can try sew. also, another question, there is another consew machine which is 227, same price as 206rb. which one is better for making leather purse or handbag, wallet stuff? Thank you guys always!
Thank you! Andrew for your reply. I missed that machine, it sold already. but! I saw another one, is Consew 206rb. also, Andrew, do you know which one is better, consew 206rb or consew 227/226?
