Content Count
46 -
Posts posted by lwleathers
We can make the masonic stamps for you. It takes around 2-3 working days for it to be ready to ship.
Http://lwleathers.com/product/leather-stamps
Agree, wouldn't risk it. It's better to have a vector graphic prepared for the signet and have a proper leather stamp custom made.
We could help with the vector file preparation and stamp making too.
We provide custom font letters or alphabet stamps made of brass, any font, any size!
They can come with an interchangeable stamp holder or individual stamps.
Hi there,
We are are specialised in custom made leather stamps! We offer 4 types of stamps depending on your preference.
1. The standard $38 one uses a c-clamp for emboss. Please see the instructions here: https://www.dropbox.com/s/qt3pmhdum5y86dn/instruction.pdf
2. We have one that is designed for use with arbor press ($68) Sometimes it can be hammered on too depends on the size of your design. http://lwleathers.com/product/custom-leather-stamp-for-arbor-press-stamping-embossing-branding-leather
3. We have another one that comes with a hammering handle ($98). The stamps are interchangeable, perfect for multiple stamps (additional stamps are $38 each only) http://lwleathers.com/product/custom-leather-stamp-with-hammering-handle-for-leather-emboss
4. We also provide a custom heat embosser for leather stamping ($128). Please see the video in the link below. It’s very easy to use and it takes only seconds to have a deep and long lasting emboss. www.youtube.com/watch?v=PNeDelNRqEU http://lwleathers.com/product/leather-stamp-with-heat-embosser-for-embossing-stamping-leather
* We provide custom font alphabet set too! http://goo.gl/Xaw1dE
Good tips on using acetone! I wonder if it would leave a mark on natural veg tanned leather?
We now provide a 500W branding iron with temperature adjustment too! It's efficient for stamps up to 4 inches wide: http://lwleathers.com/product/electric-branding-iron-for-leather-wood-temperature-adjustable
Hexacon electric makes leather brand irons. I currently use a 250w iron. Anything under 100w won't get hit enough. A torch will leave a soot.
I'll use a little acetone to dampen thin 2-3oz leather.
If I use water the leather will curl. I need to get a temperature control and play with the settings.
I also use a fine bristle stainless brush to clean the brass stamp inbetween stamping.
Thanks a lot Jake! Would love to see how the emboss turn up on you works!
I just received mine too and it works flawless. Really like it and will be ordering more. Thanks!
Thank you so much Robert for your nice review!
A leather case for the stamp is a great idea! Aluminium or Brass stamps are relatively soft metals, they could be damaged if it's got knocked down from the table.
Hi there,
We are rolling out a arbor press with temperature control this month which you might be interested in. The price range will be $600-800 including the stamp and/or cutting die. I'll keep you guys updated once I've fully tested the system!
So, the $38 stamp should not be used on an arbor press?
Hi there, the $38 one is only 8mm thick and we do not recommend using with an arbor press because after prolong usage, it tends to crook. We recommend the 25mm thick one for arbor press.
Thanks lightningad! Our website is actually www.lwleathers.com
We have 4 types of stamps depending on embossing preference.
1. The standard $38 one uses a c-clamp for emboss. Please see the instructions here: www.dropbox.com/s/jo2i4vjgxymko6t/instruction.pdf
2. One is designed for use with arbor press ($68) Sometimes it can be hammered on too depends on the size of your design. https://www.etsy.com/listing/109001883/custom-leather-stamp-for-arbor-press?
3. We have another one that comes with a hammering handle ($98). The stamps are interchangeable, perfect for multiple stamps (additional stamps are $38 each only) www.etsy.com/listing/118992398/custom-leather-stamp-with-hammering
4. We also provide a custom heat embosser for leather stamping ($128). Please see the video in the link below. It’s very easy to use and it takes only seconds to have a deep and long lasting emboss. www.youtube.com/watch?v=PNeDelNRqEU www.etsy.com/listing/98894284/custom-leather-stamp-with-heat-embosser
I got a very nice brass stamp from LWLeather.com (they advertise on this site) and the web address will take you to Etsy.
mines a 3x3cm square - be warned though, you will need a decent amount of force to ensure a clean impression. I am gonna buy an arbor press to get the stamp consistent.
the detail is incredible - you can even see the Roosters eye on the leather and its almost microscopic!
We have 3 types of leather stamps and devices depends on your preference of embossing! The standard $38 one uses a c-clamp for emboss. Please see the instructions here: www.dropbox.com/s/jo2i4vjgxymko6t/instruction.pdf
We have another one that can be hammered on. ($98) www.etsy.com/listing/118992398/custom-leather-stamp-with-hammering
We also provide a custom heat embosser for leather stamping ($128). Please see the video in the link below. It's very easy to use and it takes only seconds to have a deep and long lasting emboss.
If you are interested in it, please let me know! Listing: www.etsy.com/listing/98894284/custom-leather-stamp-with-heat-embosserPlease send us your design (AI vector or high resolution JPG) to calvin@lwleathers.com and specify the size so we can discuss further!
Attached are some samples of leather branding with our heat embosser!
Stumbled upon an interesting DIY blog post on leather hot stamping using an iron and thought some of you will like to try it out at home too!
http://minkudesign.c...011/09/04/1682/
If you want more control on the temperature and final degree of darkness, we provide a heat embosser with temperature control!
Hi Clair,
Thanks for sharing the stamp you made on Shapeway! I wonder how big (dimension of the design) was the stamp you made?
Cheers,
Calvin
We are now offering a special 10% discount on our stamps and branding tools for fellow members on leatherworker.net.
Valid till 31st December!
Our stamps are made of brass and they are absolutely fine using a poly maul as John mentioned.
In regards to shipping I know Infinity ship out side the US and Phillips dont, what about the rest? The Etsy stores mention only an estimate within the US.
We ship worldwide!
Hi all,
We are specialized in making custom brass leather stamps for fellow leather workers! We provide different versions of stamps that suits your branding preferences! Price starting from only $38 + shipping.
(click on the links for details)
Stamps
Brass plates - for use with table top vice clamp or arbor press
Stamps for hammering - the old school method
Electric Branding Tools
Heat embosser with temperature adjustment - easy and convenient for branding leather. It takes only seconds for a long lasting emboss!
500W heat embosser with temperature adjustment - Best for large stamp up to 3x3inch!
26 letters set with holder - we can custom make almost any font you like! It can be used by vice-clamp or with our heat embosser.
Just send us your design and we can make your unique brass stamp to high precision by CNC machines.
We are fast! A custom stamp can be made ready to ship in 3-5 days. We can even ship next working day for rush orders (additional cost applies).
There is no limitation to size so please email me to discuss! calvin@lwleathers.com
Whats wrong with the plastic ones?
Metal stamps like steel or brass are much more durable than plastic, especially the ones for hammering.
You can consider our custom letter set and handheld heat embosser!
Letter set:
https://www.etsy.com/listing/112742933/customized-alphabet-letter-stamps-for?
Heat embosser:
https://www.etsy.com/listing/112736766/electric-branding-iron-for-leather-wood?
If it's a hot press, you could use foile for it, I suppose. Which one, and are you happy with it?
thx
I have used a three inch disk but got best results with smaller. I mainly use it for 1.5" x 1" oval stamps for logos
Ray
Indeed, larger stamps of regular thickness (around 8mm) tend to crook after prolong pressing by small arbor press. Smaller stamps under 1.5x1.5 inches will be perfect.
We now provide thicker material (20-25mm) for larger stamps to avoid the problem. But still, it's better to have a larger arbor press (with a larger pressing head) for more even emboss.
Or you could try our heat embosser with custom made stamp, it's easy to use and doesn't cost you a fortune!
https://www.etsy.com/listing/98894284/custom-leather-stamp-with-heat-embosser?
We provide affordable branding irons for leathers:
This thread is old but I guess there must be still someone looking for heat branding with holders.
Here you go:
We can custom make any font, any size: https://www.etsy.com/listing/112742933/customized-alphabet-letter-stamps-for
This holder could be used with our high power heat embosser:
DIY Hot Leather Stamp
in Leather Machinery
Posted · Report reply
We offer economical heat embossing products!
We offer 3 types of branding irons/heat embossers for leather.
1. 40W heat embosser for veg tanned leather and stamps up to 4x4cm.
2. For working with a more variety of leather, more precise control of temperature and gold foiling, the 300W heat embosser with digital control is recommended:
http://lwleathers.com/product/custom-wood-branding-iron-300w-with-temperature-control
3. The most versatile instrument will be a heating arbor press
http://lwleathers.com/product/heating-arbor-press-for-leather-wood-paper-emboss-and-gold-foiling
Cheers,
Calvin
www.lwleathers.com
Custom Leather / Wood Stamps and Branding Tools
*We provide LEATHER CUTTING DIES & Alphabet Set now!*
FB: facebook.com/lwleathers
