the deacon
Everything posted by the deacon
How to make a press for moulding leather pouches and such
the deacon replied to RockyAussie's topic in How Do I Do That?
Thanks Brian. I was thinking about adding a peg to my mould that would line up with the punched hole for the snap. This may stress/elongate that hole, but could also help mitigate pull down.- 74 replies
- moulding leather press
- handcuff pouch
(and 1 more)
Hey Brian, I am curious. Every time I have tried wet moulding a leather case, the open edge of the leather gets pulled out of shape as the mould presses. How do you overcome this? thanks- 74 replies
- handcuff pouch
(and 1 more)
Hey Floyd, I put the cover plate mating side down on a piece of glass to assure that it's not warped. I don't see any irregularities on the frame side. I've gone over and over it and can't spot anything. The irregularity of stitching and this cover plate issue is now cutting into production time so I'm going to have to bring it to the repair shop. I'd like to be much more self reliant but I can't figure this one out. Thanks for the help
after I made the lateral adjustment to the feed dog, the needle is fairly out of alignment with the feed dog hole. I'm now suspecting that the throat plate is the issue and miss aligned. The design has the screws that anchor it to the frame toward the bottom. I noticed that when I screw it down, the top angles toward the left (away from the base), thus touching the feed dog. If I leave it loosely screwed it seats straight and the feed dog does not hit it. Sure is weird. I'm not sure if it will be fixed by getting another throat plate or if I shim it in some way so the throat plate mates with the frame square, keeping the top from shifting. Anyone ever run into this?
Stitch unbalanced every few stitches
the deacon replied to the deacon's topic in Leather Sewing Machines
ok, moved up to an #18 needle and still had the same issue. Then did 4 layers of the #10 duck and that worked much better, if I look closely (and into the needle hole) I can see the knot favoring the top side. This doesn't solve the problem as my work only calls for 2 layers. No knots or twisting happening through the thread guides or off the spool this one is stumping me. -
Thanks so much everyone! Great suggestions. I'll try them out and report back. -
good thought. I have tried a new bobbin. I looked at the tension discs, couldn't see any burrs -
I have been trying to dial in my Juki 341 for the past month. I'm not at the point where I'm not sure which variables are effects which outcomes (though I have been trying hard to only change one variable at a time). I can't get the center of my stitch consistently in the middle of the material I'm sewing (example here is two ply #10 canvas duck, size 16 needle, 69 bonded nylon thread. I have used yellow thread in the bobbin to highlight the issue). Seems like every 4th stitch or so the stitch pulls toward the top of the material. I have adjusted the tension and it doesn't eliminate this pull up every so often. Thanks for the help all.
Thanks Uwe. The needle is fairly well lined up with the center of the hole in the feed dog, so I'll leave it as is for now. Thanks for the Engineers manual for the machine. I've added it to my library
Hi all, While doing some work on my machine I noticed that the back right of the feed dog is rubbing on the throat plate. I think it is very slight as the only way I knew was that the inside edge of the plate was polished. I'm thinking buying and changing out the feed dog to see if the issue persists. Before I do that is there some kind of set screw or adjustment to make that would center the feed dog more evenly inside the plate?
One more thing. I noticed there was some play and an audible click with the finger that pulls back the bobbin switch. Are those normal tolerances?
Thanks Wiz. I made those adjustments, I didn't see too much change in loop tension. I also moved the spring stop per Uwe's video on adjusting the check spring tension. I think it's pretty good. I have to do some more thorough sewing to be fully sure. I did see another issue while doing all this. It has to do with the feed dog. I'll start another post so as not muddy up the valuable info here.
Uwe, Exceptionally helpful video, Danke Uwe. The bobbin case timing was off. I have adjusted and have much better results. I noticed on your video the loop that is created by the hook is much tighter than mine which seems to me would cause less efficient stitch execution and/or sloppier stitches (first video). Is there an adjustment to make to tighten that up. Also I noticed there is a little bit of play with the finger that pulls back the bobbin switch, there is also an audible click when moved (second video). Is that normal or is this part loose in some way. Again, thanks so much for a great video tutorial. Dieter
I applied some oil when I re installed the basket. This may have accounted for the machine to be working a bit better than before. I did run my thumb nail around the chase and basket. I didn't feel any burrs. I suppose I could order a new one and see if that solves the problem. I've never adjusted/set the timing on the machine. I'm wondering if that could be the issue?
scratch that. After test sewing it's still happening, though intermittently. Ahh the joys of machine maintenance.
reinstalled and there is no more binding. I have no idea why it is working now. Perhaps I didn't notice if the bobbin case was not inside the notch when I first took it apart. One question. I notice that my bobbin opening lever has an ever so slight bit of play and a distinct clicking sound when wobbled. Should that be? thanks for all the help!
Thanks Constabulary. Just looked and the set screws are well set. I did take out the bobbin basket and it caused the binding to go away. So must be something with the bobbin. Could it have been a bobbin case opening lever adjustment issue? Is there a good resource on how to dial it in?
Constabulary, the exact issue was present with the throat plate attached, i removed for the video it in case it was easier to see and diagnose. With the feed dog shaft removed the issue persists. Sadly I don't know what the hook driving cone gear looks like. Does anyone know where to find a parts diagram for this machine? The owners manual doesn't give good diagrams.
Thanks Wiz and Uwe, Just to clarify, I never pushed through on motor power, (actually the motor couldn't push through). I manually turned with the wheel. I'll pursue your recommendations and let you know what I find!
Hi all, An issue has cropped up with my 341 and I can't figure it out. It kind of appeared after a month of down time for the machine. Thought it might be a lubrication issue, so I oiled all points to no effect. I don't see the needle striking anything. The seize up seems to happen on the up stroke of the needle, I can "push" through it if I turn the belt pulley. Any thoughts? Thanks.
Excellent! Thanks guys
Wow, never thought it would be tough to wrap my head around this. Looking for L and R presser feet for my Juki Ls-341. Can anyone offer guidance? I've seen a bunch of juki feet but nothing called out my model specifically. thanks deacon
Thanks Wiz
Hi all, I just got a Juki 341 and it does beautifully on both leather and canvas. A few of my bag designs have both leather and canvas (leather bottoms with canvas making up the majority of the bag) in which case one seam transition from leather material to canvas. I'm using 4-5 oz leather and 10oz-18oz canvas, 69 thread. For the leather I normally use a leather needle that is cuts a diamond hole. This poses a problem for the canvas as it cuts the fibers. Is anyone out there working with these materials and have found a needle that can be used for both, so that I don't need to sew the leather section of the seam, then change needles and sew the canvas section? Thanks deacon
I didn't know that, thanks for the info!
