Everything posted by BorisVanJr
Hi, shoe soles like this are made from not so good quality thermoplastic material, they cost about 5-7$ and they strongly rubbed. There are another soles in the same prise range made from polyurethane foam (i used them on my first boots and hiking shoes on photo below) which are maybe not so good looking but lighter and more robust.
- 15 replies
I just thought that you live in US, that's why i recommended, but it's nothing said on your profile where are you from. Good luck))
- 15 replies
Thanks, I bought those soles here http://www.lvivplast.com/ in Ukraine (i living here), it will be impossible to you The Logan by them here. Where to by i dont know, you can try to find in the US, it will be better for you. I done some new hiking shoes for a few month ago using the same technology, aweryone can watch them here http://shoemasters.org/forum/gallery/image/595-trekingovie-krossovki-4/
- 15 replies
Thanks you all, glad that information are useful. When i was trying to make my first shoes http://leatherworker.net/forum/index.php?showtopic=45616, it was no information about how to make modern hi tech shoes at home, especialy without professional machines, that's why i thought to share some own experience. A few days ago I finished new hiking shoes http://leatherworker.net/forum/index.php?app=gallery&album=2238 Simply put some piece of paper on shoe last and then cover it with sewed together these parts http://i-fotki.info/16/5219ef1170d88daf885f5eac7e103a4f2eacf5174033616.jpg.html, draw contour and then add thickness of materials you using, thats all. http://i-fotki.info/16/3397ce55f4fd2726a32ae25a2fafbc982eacf5182558507.jpg.html Its Kenda professional glue for shoemakers. Can be used any kind of brands, I only showed the type of glue.
- 15 replies
From the album: My Trekking Shoes
Hello! Let me present to you my third work. My first work were these boots http://leatherworker...showtopic=45616, design Merrell Chameleon Wrap, and the second, running shoes, design Garmont Escape PRO 9.81, on photo bellow. And here shoes numbered 3, with my own design and own logo, which will be discussed here and manufacturing technology, which I would like to share with you. The first thing I began with - design, available materials and furniture. Despite all this, you can correct design subsequently as I did. I began the design with a clean sheet of paper. Sketched a few pictures I settled on this design, considering the design features and attachment parts sequence - this is important , otherwise it will be impossible to attach it properly. It is also important to think about where and how will shape the bend. To improve inflection, I used an extra pair of belt loops on the shoe vamp. Here demonstrated only one of many possible designs of shoes, the rest depends on your imagination. http://i-fotki.info/...031277.jpg.html "By approving the project" could begin. Put all materials on shoe last (except upper material) in the right amount and manner as they would be in the finished shoe. It is necessary to put a thickness of insole and middle sole. For further winding of shoe last, use masking tape 20-25mm wide, wider is not recommended. Masking tape should stick well, but not to be wax outside, otherwise it will be bad stick and when removing the shell it can lose shape. http://i-fotki.info/...031431.jpg.html http://i-fotki.info/...031468.jpg.html http://i-fotki.info/...031491.jpg.html Glue tape needs with a little overlap, preferably without wrinkling. After sticking enough thickness of tape, insert shoe last in the outer sole and outlines the level to the visible part, below which all will hide. http://i-fotki.info/...031619.jpg.html http://i-fotki.info/...031648.jpg.html We should also mark the axial lines, front and rear. Now we can begin to design. Draw is best with conventional ballpoint pen, using gentle pressure and instead of the eraser, use pieces of masking tape. Underway, you can change the design somewhat, if in dimension will not like something. Since the right and left side is not quite the same, move all lines using vellum, for example, you will not succeed. Help you centerlines and tailor measuring tape. After completion, you must draw harder all the necessary lines, to avoid confusion. http://i-fotki.info/...031709.jpg.html http://i-fotki.info/...031815.jpg.html http://i-fotki.info/...031845.jpg.html Using sharp knife, making slit at axial lines and lower edge, to divide into two parts. By dividing, cut along the contour, including the toe cup as the most convex part. Parts became more flat, but they still can not be cut, they must be glued on thick paperboard, while leveling and cropping. More detailed process describes here http://www.youtube.c... for shoes&sm=3 http://i-fotki.info/...032008.jpg.html http://i-fotki.info/...032046.jpg.html Now is necessary to make slits on lines for creating patterns. http://i-fotki.info/...032207.jpg.html http://i-fotki.info/...032235.jpg.html Creating patterns is most responsible for connection all parts. Using the main patterns make all external parts. It is necessary to consider all overlaps, overmeasure and mark centerlines. You should also specify the right and left sides, as well as the front to each side. http://i-fotki.info/...032285.jpg.html http://i-fotki.info/...032313.jpg.html http://i-fotki.info/...032340.jpg.html After making all patterns, you can begin to cut material. Also note, if were made some amendments to the upper, it is necessarily to make them on patterns. http://i-fotki.info/...032387.jpg.html I have a regular sewing machine (Singer copy), therefore the manufacturing technology reminds classic shoes, where is no need of a post sewing machine. I made some improvements for greater sewing accuracy and larger thickness. I replaced original hand driven mechanism and attached own lever directly on the wheel. Instead of three stitches per one revolution, now it makes one (used for hand sewing of large thickness). Undergone revision and presser foot, making it narrower and shorter, increased downforce, improved visibility and accuracy. Needle used conventional 110, although it is better to use reinforced for leather, thread polyester 40. http://i-fotki.info/...032557.jpg.html http://i-fotki.info/...032583.jpg.html http://i-fotki.info/...032604.jpg.html Before sewing, machine needs to be adjusted for a specific material thickness and test on a separate piece. My primary material is haberdashery suede 1-1.2 mm thick. http://i-fotki.info/...032654.jpg.html Should start with the basic parts, on which is necessary to mark those details, which will be sewn first. Because of the sliding effect and high downforce of the presser foot, one material slides relative to another, I found a simple solution for this problem, parts before sewing, I gluing together after what, concentrating on precision stitching. http://i-fotki.info/...032713.jpg.html Since suede is not for footwear, however, it is strong enough, to provide proper rigidity of some parts I’m using 1mm thick cotton fabric. http://i-fotki.info/...032779.jpg.html http://i-fotki.info/...032806.jpg.html Having measured braid using patterns, glue and sew them, then you can sew the side part. Do the same with the second half and then sew together both parts. Stitch on these parts is 2.5-3mm. http://i-fotki.info/...032978.jpg.html http://i-fotki.info/...033039.jpg.html After receiving a single piece (upper), it’s ready to make a heel cap. Since I did not have a proper shoe last (proper shoe last on pictured below), I made a separate billet for forming the heel, but with a normal shoe last is done directly on it. Cut two pieces of cotton fabric, stretching and gluing together with SAR 306. When dried, transfer lines with pattern and cut. http://i-fotki.info/...033091.jpg.html http://i-fotki.info/...033129.jpg.html http://i-fotki.info/...033381.jpg.html http://i-fotki.info/...033431.jpg.html http://i-fotki.info/...033457.jpg.html http://i-fotki.info/...033479.jpg.html Then glue it on heel in folded position on shoe last and sew it with stitch 2.5-3mm. http://i-fotki.info/...033535.jpg.html http://i-fotki.info/...033559.jpg.html http://i-fotki.info/...033593.jpg.html http://i-fotki.info/...033616.jpg.html Now you can begin with layer over the heel of polyurethane foam and lining. There are no patterns for these parts, so lay out on the shoe last, blank sheet of paper, draw around the top and cut. There no corrections for polyurethane foam, but lining must be recalculated - 1mm suede + 3mm polyurethane foam + 3mm wool interlayer + 4mm lining allowance = minimum 11mm total must be added to the upper contour, on which will be sewn lining. This is necessary to ensure that all will twist neat. http://i-fotki.info/...033673.jpg.html http://i-fotki.info/...033705.jpg.html http://i-fotki.info/...033735.jpg.html Sew need right by the polyurethane foam, for smooth edge, stitch 1.8-2mm. For insulation using natural wool, material thickness about 3 mm, the same material used on the first boots. Gluing with SAR 446, applying thin layer on wool and suede. The photo shows masking tape, 5-8 mm to the edge, where wool layer will be needed to cut. http://i-fotki.info/...033796.jpg.html http://i-fotki.info/...033827.jpg.html Then gluing lining with SAR 446, also applying thin layer. http://i-fotki.info/...033883.jpg.html http://i-fotki.info/...033921.jpg.html All excess need to be cut and sewn, on that edge, where the masking tape was. At this stage, the shoe begins to appear. As can be seen on the photo, it keeps form well, but the final forming will be at the very end. http://i-fotki.info/...033977.jpg.html When the upper is ready, next part you need to continue - tongue. There also no patterns, but you can estimate the length using upper, the width of the tongue I took from my sport shoes - 100mm. Gap width in the shoe vamp is 40mm, respectively adding 6mm allowance, will be enough for sewing. On a sheet of paper draw everything and make pattern, cut the mesh and lining without any overmeasure. Put some polyurethane foam (about 3mm) on the tongues top (for thickness and strength) and sew together mesh with lining face to face. Then glue mesh with wool layer and extroversion. http://i-fotki.info/...034032.jpg.html http://i-fotki.info/...034054.jpg.html http://i-fotki.info/...034191.jpg.html http://i-fotki.info/...034218.jpg.html http://i-fotki.info/...034262.jpg.html http://i-fotki.info/...034286.jpg.html Cut a piece of suede, glue and sew. Mark the braid and sew. http://i-fotki.info/...034383.jpg.html http://i-fotki.info/...034406.jpg.html http://i-fotki.info/...034426.jpg.html Connect together tongue and upper with clearance 40mm using SAR 446 and then sew together stitch to stitch. Mark border of the toe cap on upper and glue with SAR 446 along the edge, as well as toe cap, connect and sew, stitch is 2.5-3mm. http://i-fotki.info/...034718.jpg.html http://i-fotki.info/...034749.jpg.html http://i-fotki.info/...034859.jpg.html http://i-fotki.info/...034891.jpg.html http://i-fotki.info/...034918.jpg.html http://i-fotki.info/...034939.jpg.html Now put the upper on the shoe last, I leave allowance in 20mm for bend under the shoe last, only for upper, side parts, heel and toe cup should be in the slice with the bottom. After toke the upper, cut out the toe reinforcement from cotton fabric, glue with SAR 306, tighten in place. Once again, make sure that upper is in the right position, remove the staples and glue. Cut off all suede relief and glue suede center part. When it's all ready, it's time to form the shoe. We need to warm all shoe parts, that has inside cotton fabric and tap with a hammer, to complete forming. After that, shoe will keep the shape for a along time. http://i-fotki.info/...035595.jpg.html http://i-fotki.info/...035647.jpg.html http://i-fotki.info/...035683.jpg.html http://i-fotki.info/...035713.jpg.html http://i-fotki.info/...035741.jpg.html http://i-fotki.info/...035767.jpg.html Basically shoe are ready for gluing outer sole, but I would like to stamp on it own logo. To do this, take a picture of the shoe from the side, where logo will be, open the vector program Corel Draw, import photo, create a logo in scale and print on plain paper. Take sticky film Oracal, and cut out the logo with sharp knife, slot only to the film substrate. Unstick from the film unnecessary parts and glue masking tape over all parts. Cut and stick the logo in its place. Carefully remove the masking tape, leaving all separate pieces in place. Glue around with masking tape to avoid smudge of shoe. Preparation is completed and we are ready for rubber coating. As rubber coating I’m using SAR 306 and 30-40% of aluminum powder (for metallic effect). Using brush, apply thin layer and let it dry for a couple of hours. With precision knife cut glue on film edges for smoothness of the logo edges without rips. Due to a thin layer of coating it obtained fairly resistant to damage. http://i-fotki.info/...035832.jpg.html http://i-fotki.info/...035873.jpg.html http://i-fotki.info/...035901.jpg.html http://i-fotki.info/...035924.jpg.html http://i-fotki.info/...035950.jpg.html http://i-fotki.info/...035974.jpg.html http://i-fotki.info/...035995.jpg.html http://i-fotki.info/...036020.jpg.html http://i-fotki.info/...036039.jpg.html http://i-fotki.info/...036068.jpg.html http://i-fotki.info/...036089.jpg.html Finishing stage, gluing the outer sole. Left the upper on shoe last and insert it in outer sole, outline with pen about 1mm below the level of the outer sole. Apply SAR 306 on surface, coat over line and let it dry. The outer sole is made from thermoplastic and I need degrease it with special composition Satreat and only then glue it. When the glue dries, it does not stick at all, conversely it's slides. Insert shoe in the outer sole, heat bottom side with hairdryer and press for a few seconds. Then you can easy heat side parts and tap with hammer. By this way it’s easy to make clean connection between upper and outer sole. http://i-fotki.info/...036284.jpg.html http://i-fotki.info/...036312.jpg.html After a few hours, you can remove shoe from the shoe last. It remains only to make insole. For insole I am using - 2mm thick polyurethane foam, 3mm wool interlayer and 3mm lining. http://i-fotki.info/...036371.jpg.html Glue the insole on its place and do all the same with the second shoe and enjoy your work. When placing this article on other sites link to this forum is required. Sorry for not exact terminology and not perfect english. Good luck!
- 15 replies
Hand Made Boots Inspired By Merrell
BorisVanJr replied to BorisVanJr's topic in Shoes, Boots, Sandals and Moccassins
Off course i have not. -
From the album: My hiking boots
Let me introduce my first self made boots. Everybody are welcome to watch on youtube -
Yes, from a certain point of view. For example, if i will make something for own use i can put any kind of logo, as a commercial, i need pay for patent rights. I used this LOWA logo, because i did not found the solution for my own logo, but i found it and my second pair of shoes, will carry it! -
Thank you wery much Paul. I am glad that you like it! The most important (special) thing in shoe making, is shoe last, all another can be replaced with casual tools. Without shoe last, you can't be able to do something good (oun experience). I dont think that this, machine that i have, is too specific, right now i got a new one, like this. All you need (special) for this machines is leather needles. The most important thing that you need, is wish and imagination. Shoemaking, its just one of mine hobbies. -
I did not realise how good those shoes will be, thats why i did not take almoust any pictures of it in process. Those photos on video, is all i got, but as i sad before i working now on second pare of shoes, it will be the same "hi tech" style shoes with similar construction and i will take more detailed pictures of all process i will do. You can ask about what you are intresting, i will answer with pleasure. -
Its wery simple, because i could not find MERRELL lable for it, all it was just ADIDAS, NIKE, PUMA, LACOSTE, the only hiking shoes manufacturer label was LOWA. The second shoes will carry my own logo and own design. My logo is on the left -
Thanks benlilly1 for your comment, This music i composed in Dance eJay 2 for almost seven years ago and i could not find the place for it, until now. -
Hi! Thanks for your pleasant reviews, I am very pleased. It is realy my first shoes i ever made. I have some drawings of original concept. I was looking for robust technology for my shoes and i found only one type of material which i could perfect to use (IMHO). It is rigid PVC transparent film. I used 1mm thick, it is not brittle, it can be easily forming when it hot and the most important for me i can stick it with desmocoll, to meke the construction strong, rigid and robust. Here's a link where you can found it http://www.alibaba.com/showroom/clear-rigid-pvc-film-for-vacuum-forming.html -
Greetings to everybody! Here i want to show some little expirience about creating boots. This is my first shoes i ever made. I very much like older version of Merrell shoes like chameleon series, which in production no more and i thought why not to make them by myself. It was interesting job that i done. Everybody are welcome to watch result on youtube.If you have some questions, i will answer with pleasure.
Greetings to everybody! Here i want to show some little expirience about creating boots. This is my first shoes i ever made. I very much like older version of Merrell shoes like chameleon series, which in production no more and i thought why not to make them by myself. It was interesting job that i done. Everybody are welcome to watch result on youtube.If you have some questions, i will answer with pleasure. to be continuum......
