LeatherNuebie
  • Content Count
    38
Posts posted by LeatherNuebie
  1. i'm not sure how far along you've gotten with this project. but i have a suggestion for the collar. it's something i did to my joe rocket sonic jacket. the band collar is nice and it's used on man motorcycle jackets. however, i think they're rather non-functional when they are so flat by design. what i did was to open up a stitch on one end of the collar and (using a coat hanger) push a round neoprene foam tube up inside of the collar. it basically made the collar have a more round and dimensional look to it. i simply stitched the hole up afterward. you might want to think about doing something like this.
    This sounds interesting. Do you have any pictures of what this collar looks like on your jacket? I would love to see it. Ride Safe!
  2. UPDATE: So I've finally documented what I wanted to do to this jacket. Basically, I want to convert this jacket to a more fitted cafe racer style jacket which is pretty extreme alteration-wise.
    Design Elements
    Basting
    I've laid down some stitches to help me get a sense of the fit I want. Here you can see several red stitches I've made along the sleeve and along the body. Boy, these were tough to put in. I broke a needle trying to push it through. Putting these stitches in was slow going. I can't wait until my tools arrive to make this job easier.
    Basting
    Sleeve Preview
    Here is one side of the jacket with fitted sleeves and the other side unmolested. The jacket looks worse than it really looked when I wore it. Since there is no lining and I'm only wearing a tee shirt (typically wore a sweater with this jacket, it looks really bad. However, the sleeves were longer than they should have been. The fitted sleeves should look much better and less wrinkled when the are fully stitched. Note: the body has already been taken in.
    Sleeve length preview
    Length Preview
    Here is the jacket with the bottom folded up and under. It's starting to look worlds better.
    Length preview
    Supplies
    I've purchased some supplies that I'll need to keep this project moving along. The thread is polyester. I've learned from this site that Poly thread is very strong. The red thread is too see if I like the contrasting stitch color. Am I that brazen to use a high contrast thread on hand stitched parts?! I've been known to do dumber things but we'll see. I also learned that using contrasting colors are great for basting stitches. The zippers I found were pretty cool. They are very stealthy and will look great if I choose to leave the zipper slits raw or if I finish them. The black snap buttons are for the collar strap which I intend to put on. I wish I could find a black matching main zipper that isn't plastic.
    Some material
    Collar
    The collar was made up of 2 pieces of leather. Since I am basically folding over the collar to make it a band collar I didn't need the second layer as it would have made the collar too thick. The part not seen (back side of collar/shown removed) was made of a thinner grade of leather perfect for use as the pieces under the wrist zippers.
    Backside of collar removed
    Collar panel removed
    Collar work
    Here, I've used binder clips to temporarily hold the collar in place. It was all I had that was handy. This looks to be the most difficult part for me as I'll have to make the stitch holes which need to line up to the opposite stitch holes when they are connected. The curved leather piece in the last pictured would look cool stitched with contrasting red thread. It could break up the black monotony back there.
    It should look pretty nice when it's finished.
    Collar Stitching
    Working The Collar
    Next Steps
    Once I've confirmed the sizing, I'll lay down the body and sleeve stitching. I will then finish the sleeves installing the zippers.
    My fingers have taken a beating over the past few days so I'll be taking a short break. I can't really do much until my stitching wheel arrives next week.
    I do have a question, when I begin stitching what would be the best type of stitch to make. I was thinking of using the double needle method? Is that good?
    Also, it's almost impossible to see any pilot holes I make in the unfinished side of the leather, are there any tricks to help me see the holes better when I start to use the stitching wheel? Thanks!
  3. The longer brown stitches are probably what are called basting stitches. They are put in first. Long stitch length means easier to pull out if you need to make adjustments. Once it is basted together, then the finish sewing is done. The jacket is assembled in sections, not all basted together first before final sewing.
    Most are not glued before sewing. Super glue may be used so you can assemble pieces since you can't always clamp or use pins like tailors do. Where you can get away with it, you can use a stapler to "pin" pieces together. Put them a little ways away from your stitch line, on the hidden edge, so you won't have staple holes showing.
    I did a leather coat many years ago on a home sewing machine. Used lamb skin glove leather. Wasn't fancy but was nice and warm with a quilted lining.
    Tom
    Thanks Tom! Mystery of the brown stitch solved! That's good to know. The stapler trick is also a good tip. I'm sure I'll be using that one quite a bit.
  4. Leather Jacket Autopsy
    For those interested in how a leather jacket is constructed (or how to take one apart) look no further. This is step one in a project I've undertaken to transform a plain boring leather jacket into a stylish, modern casual jacket.
    Dockers Leather Jacket
    Aside from it's boring nature, the jacket itself is well made (china). It is roughly 12 years old. Physically, there is nothing wrong with it, all stitching is intact and solid. I estimate it is 1mm leather. It is heavy but not as heavy as the reference jacket pictured at the end, which is 1.2-.14mm thick leather. Functionally, it was a poor jacket. It wasn't that warm in the winter and it's loose fitting nature allowed cold air to circulate around inside. I was thinking about selling it but the leather was so nice, I couldn't part with it.
    Front View
    Back View
    Poly Lining
    I like the quilted sleeve liner. I was thinking of replacing the brown material with quilted material. Maybe I'll save that for another day.
    Jacket Lining
    Seam Ripper
    This little gal has ripped many a seams. She made short work of removing the lining. Once I got the seam to unravel, I carefully rocked the ripper closer to the leather side so I wouldn't damage the lining. Also, becareful of the pointy end of the ripper. If you're not careful, you can easily put a hole in the leather. Sometimes if the stitching is very tight, I would work it from the back side. There's no turning back now :oops:
    Seam Ripper
    Attachment Points
    At various points throughout the jacket, the lining was attached to the leather with small pieces of cloth. I left them attached to the jacket, rather than the lining.
    Attachment Points
    End of Sleeve
    This photo shows the end of a sleeve (where your hand comes out) and how it's attached to the liner. It's basically a tube. The second photo shows where I started to undo the stitching.
    DSC 9458
    DSC 9460
    Lining Removed
    I worked all the way around the lining making sure I didn't undo any leather stitching. The last two photos are of the slash pocket and inside breast pocket
    DSC 9461
    Backside of slash pocket
    Inside pocket
    Liner
    Here is the liner, inside out. The off white is some sort of polyester material. This material was right up against the unfinished black leather making it off white. I would love to know what this material is called. The white material on the shoulder is not padding but thin poly material probably put there to give the shoulder more shape. They are different types of material.
    Shoulder cloth
    Strap and hardward
    Aside from the bad fit, this was probably the thing that annoyed me the most about this jacket. No matter how hard I tighten them, they would always work their way lose. I'm glad to see them go. These holes can easily be stitched shut and no one would be the wiser. However, I'm not going to stitch them close until I have thought things through. I may convert these straps to button straps which should be fairly easy to do. Or I may leave them off completely. I was also thinking about using the strap on the collar when I convert it to the short style. At this point, I haven't finalized my design so I'm still kicking around ideas. One thing is for sure, I intend to reuse all the material I can.
    Side strap removed
    Holes where strap and hardware once were
    Repurposed strap and hardware
    Reference Jacket
    Pictured next to the project jacket is my favorite leather jacket. It is the icon Motorhead jacket. It is heavy (1.2-1.4mm leather) and keeps me toasty warm in 30 degree weather wearing only a long sleeve tee shirt underneath. It is form fitting and body hugging which allows it to retain body heat better than most jackets I own. The lack of collar allows excess heat to escape easily. Surprisingly, my neck never gets cold and I never wear a scarf. I'll be using it to gather measurements, compare and contrast manufacturing process and styling cues for my project jacket.
    Reference jacket with project jacket
    What I learned
    It was fun taking this jacket apart. I have always been curious as to how a leather jacket was made. The jacket was stitched together with 2 types of thread. A thinner black thread which was used and is used anywhere any materials are stitched together (leather to leather or leather to liner). Then there is a thicker brown thread that seems to be used to reinforce the stitching throughout (leather to liner). It appears less, maybe 1 brown stitch for every 5 black stitches. There doesn't seem to be any glue holding any of leather. Everything seems to be stitched. I understand that glue is commonly used in the manufacturing of leather goods. Thankfully, I don't see any here.
    Next Steps
    I need to finalize my design elements, getting it out of my head and get it on paper. Hopefully I'll be able to update this thread with my progress.
  5. At the very least you are going to need:
    • a really good, but small awl
    • a good pair of leather cutting scissors
    • a good pair of cloth cutting scissors (believe me they are not the same, . . . you need 2 pair)
    • bees wax (wax your thread as you go along, . . . it'll help keep the stitches you just made, uniform and tight)
    • needles and thread
    • a really good straight edge (stainless steel with a cork back work well with leather)
    • a large wheel rotary razor cutter (I think mine is like 2 1/4 inches in diameter)
    • a cutting board made for the rotary wheel razor cutter
    • a very sharp and slim razor knife (the kind with replaceable razor tips, used by hobbyists)
    • Weldwood contact cement
    • stitch wheel
    • strop
    • drywall cutting knife and blades, . . . buy the more expensive blades, they are sharper. Strop that blade point every now and then
    Your garment should have all glued seams that are then sewn. You will have to be very careful taking the seams apart, . . . cut a thread, . . . pull the glue apart, . . . cut another thread, . . . pull the glue apart, . . . ad infinitim.
    Depending on the style, . . . you may be able to undo the side seams and take off a little to tighten that up, . . . and the back seams of the sleeves.
    You are really taking on a project, . . . but if you take your time it'll work out.
    Hobby Lobby is a good place for most of the stuff you need, . . . Tandy will have the rest.
    A salses person will try to sell you the little 1 inch or 1 1/4 inch rotary razor cutter, . . . don't buy it. Get the big one, . . . it stays sharper longer, . . . doesn't weave and wobble, . . . and by and large, for leather, is easier to use.
    Good luck, may God bless,
    Dwight
    Thanks Dwight! This is very helpful. The only thing I had on hand is a seam ripper, a rotary cutter, box cutting blades and some large sewing needles. To start, I just purchased a stitching wheel, poly thread and the book "Art of Leather Stitching" (in case I have to make wallets LOL) I did spend this AM deconstructing the jacket. Pics to follow. This is going to be a fun project.
  6. Personally, . . . instead of spending a handful of money on tools and maybe winding up with a "less than steller" job, . . . I'd just pay someone to fix it.
    Someone with a leather shop doing chaps and other garments should be able to do it for not much more than the price of the tools you need to do that work.
    May God bless,
    Dwight
    Thanks Dwight. I thought about that ...hell, I might as well buy the damn jacket and skip this nonsense altogether however, I wouldn't learn one thing about working with leather. I don't expect what I make from this to be perfect and things aren't usually perfect in the first pass but it would be a start. I'm not afraid to make mistakes or to try new things (nothing ventured nothing gained). Besides, what's the worse that can happen...I wind up with material for a dozen wallets? LOL.
  7. Hello folks. I'm happy to say this is my first post here! This looks like a great place to learn all about leather working.
    So here goes...
    I've owned this plain black leather jacket for years, the sleeves are a little long on me so it spent most of it's life in the closet. Recently, I've gotten the itch to buy another leather jacket. I pulled the old jacket out and was thinking about selling it. I wouldn't get much for it. So, I got this crazy idea to modify this jacket into the jacket I want. The leather is in great condition, it is heavy weight and it is a plain design so taking in seams here or there won't be so hard. For measuring and reference, I have 2 other leather jackets I can lift measurements from. I'm sure I'll run into technical issues later on down the line but they won't be anything this forum can't help me solve.
    The problem is, I don't have money for a sewing machine, only basic hand tools at this point in time.
    Can what I want to attempt be done with hand tools? It doesn't matter to me if it takes me months to rebuild by hand as long as the stitching looks straight and professional. If it can be done with hand tools, what are the minimum tools I will need to pull this off?
    Thanks in advance for your help.
    EDIT: It would be helpful to let you all know what I plan on doing.
    1. Shorten the length of the jacket
    2. Add zippers to the wrist areas
    3. Tighten up the sleeves so they hug my arms more
    4. Shorten the sleeves
    5. Tighten up the body of the jacket, making it more form fitting
