Content Count
50 -
Posts posted by gamli
Amazing. Just out of curiosity. What weight leather did you use.
I have a customer that wants a period correct knife sheath. All my research says that the most common material used was 1.5 to 2 mm (4 to 5 oz) calf skin. I have not been able to find a source for calf skin that heavy. Does anyone know where I might be able to find this?
Thanks
Gamli
While that setter may work, you would be better off with one thats the proper size. You could use a couple of scrap pieces of leather to test that setter before deciding to buy one. If it does not work, Tandy sells one that will
Thanks, Ill check them out.
Yes those are the type. I am restoring a placard belt and the rivets I'm trying to replace are round head brass. I was trying to find replacement rivets without haveing to make them.
That would probably help soak it a bit deeper into the leather. Post some pics of your results good or bad.
Haven't tried that. But if your worried take a large piece of scrap leather, tool or stamp a random design and give it a try before you try it on a project.
Does anyone know of a source for 1/16 dia burr rivets. All of my searches have come up empty.
Nice work. How did you attach the gold leaf?
I use a mixture of 50% neatsfoot oil, 25% beeswax, and 25% tallow (by volume) Make a paste a little softer than shoe polish. Just rub it in with a soft cloth.
Beautiful work
Never thought of that. Ill have to check the out. Thanks
Thanks. Its a large center bag with four pouchlets. The bag is mafe from onebpiece of leather.
Jarred I'm looking to make a pouch that uses a large ring at the top for an opening. You lift the ring and the top of the pouch opens. When you let go of the ring gravity closes it. There are examples on "Purses in Pieces".
Fyi another source fir chain maille links is The Ring Lord. They have everytype of ring you can think of from Aluminum to Gold.
Truely impressive work.
Looking to make a ring purse. Does anyone know of a source for the rings?
I am looking for a source for the swivel rivets used in M1912 holsters. Does anyone know if these are available?
Mrs Hicks.
Great reference article. I have started experimenting with this method of hardening leather.
Do you have any historical references for this method?
Thanks for the input Chuck.
I just combined 16 oz of tallow with about 3oz of beeswax. I'll try that and see how it works before I add any oil.
Just rendered down about 2 lbs of deer fat. Got about 12 oz of tallow. Im gonna mix it with beeswax and test it out. Is there anything else i should add? Maybe 100 % neatsfoot oil or lard?
Lion and lioness
in Figure Carving
Posted · Report reply
Thx for the info. I figured the emboss had to be fairly thick to get that kind of depth
