Pappys Leather
Content Count
61 -
Posts posted by Pappys Leather
I recently started using tape on the back of my projects when I stamp or carve. What do you about the roughness of the leather when you pull the tape off?
On 12/22/2019 at 5:04 PM, sinpac said:Sent you a template.
I would like the pattern for this also
I am looking for carving patterns for 1860 slim Jim holsters. Anyone know where I can some?
Thank you for your comments. I will do some practicing find what works for me.
This is a dumb question so be nice. I have been doing leather work for a while. But I still have problems beveling my cut lines. I see others moving the beveler along the line as they are hitting it. What am I doing wrong? I have to move then hit it. Doesn't always create a nice smooth bevel.
Looking for the measurements for making 22cal bullet loops. I found information all several other sizes. Is 32 cal larger or same size?
What do you do when the rough side of leather that is inside of a holster is really rough? I really don't want to line it.
Is there a video or something else to show how to use it correctly? I have tried several times but can't seem to make it look right. Just put it aside but now would like to use it on a project.
On 10/25/2022 at 5:00 AM, Gezzer said:Is your blade hollow ground ? If not I think you may be ready for a new one or at the very least a trip to the stones ..... but I may be totally wrong .
Here in your pic it doesn't look like you have much bevel left , I enlarged about 300%
Here is a normal picture of mine , but again they would be different if yours is hollow ground .
Yes the one pictured is hollow ground. My straight blade like yours is what I started out with but it's cuts were worst
Yes I wet the leather and let dry to start looking the color of the leather. This is a cover for a Tandy leather pouch. Maybe 2-3oz.
16 hours ago, Outfitr said:A good steep beveler will help also.
What is a steep beveler?
On 10/9/2022 at 8:09 PM, Gezzer said:Did you wet mold this ? The reason I ask is that just recently I tooled a knife sheath and then wet formed too ........ lost a lot of definition . I have since been advised to do one or the other and it worked much better .
Yes I did wet form
My latest finished one. Thinking I need to get a sewing machine and learn how to use it. Take a while to stitch theses by hand.
Sometimes when I am doing the cuts for a carving pattern, they don't seem to be deep enough to get nice even indentations when using the bvevelers or other pattern tools. What am I doing wrong? I strop my blade before start. I don't do a lot of carving for that reason. I do stamping more.
What have others found works best for cutting out leather projects as far as simplest and fastest? I have tried the round knife but not a fan. I mostly use a knife I purchased from Tandy that holds utility knife blades.
What are others using to seal your leather projects? I have used super sheen and satin sheen, using the satin because I do not want a glossy finish. I started usingFiebling's leather sheen spray so my dyes don't get smeared or taken off as what happens when wiping it on. Can Resolene be applied over satin sheen? I just fin8shed a rifle scabbard that I just used oil on it then I put satin sheen on it but thinking I should have used resolene
Adding spots to holsters
in Leatherwork Conversation
Posted · Report reply
I want to try adding spots to some of my old west holsters. I haven't been able to find any instructions. Would I need to add a lining? Any help would be appreciated
