Posts posted by AlexOstacchini
Wow, very pretty!
Super neat. Looks like you've managed to get a lot of depth in that front piece, did you make a former or mould directly around the shears?
Hi all, here is a recently completed order which was a bit of a first for me. This is a 10th Century Baltic style sheath for a Viking seax. The knife itself is not one of mine, but made by my friend at pitstone forge who specialises in pattern welded stuff from this era. For the sheath the main reference was an original from the Valsgarde graves in Sweden, with tooling patterns adapted from another in Norway from the same period. The one I copied has different designs on both sides, with the fancier stuff on the front.
I am a little ignorant about very early medieval knives so there was a big research phase involved, in which it turns out that tooling was done purely by impressing into the leather and not by cutting and bevelling like you see on later medieval and modern stuff. The patterns were therefore made using a scribe and defined with modelling tools, but the swivel knife stayed in its drawer for this one!
The sheath is formed from 3mm veg tan, and is held together only by the riveted brass clasps along the edge. The metalwork on this actually took a lot longer than the leather did, with lots of punched/chiselled decoration and little stepped cut-outs. The straps are speculative as I couldn't find much on how they were worn, but is functional and makes use of the three hanging points that the original had.
I hope you like it! Alex
Good work, tidy stamping on the basket weave and looks like a nice edge as well. Definitely better than a cloth piece of junk! To my mind 6-7 ounces is about right for this sort of thing and should hold its shape nicely.
6 hours ago, Chux said:
How do you do your dye jobs? I tried doing a design where I wanted the main focus to stay a natural color and have the background darker, so the main part "popped" like the pouch you show in 9. I dyed the background, applied resist, and then the antique gel and BAM!!! The parts that I left undyed, well it got dyed...
Thanks, much the same as you describe really. My process is as follows-
1. dye the base colours. For most of my background texturing I will paint the dye in with a paintbrush.
2. Neetsfoot oil, applied over the whole piece with a sponge, but focusing mainly on the natural areas. Be aware though that this darkens colours quite a lot.
3. Resist- I use fiebings tan kote for this. Quite often now I will give it a second coat after the first has dried.
4. Antique. Fiebings antique finish in this case, worked into the recesses with a sponge, then wipe off excess.
5. Once this has dried I give it a final polish with tan kote, which cleans off any antique that is still on the raised areas.
I always try and give each stage a day of drying time. Maybe not necessary but it works for me and when I have tried to rush through things it never seems to come out very well. What product are you using for the antique? I used to use the eco flo gels and couldn't get the results I wanted, then switched to the fiebings finishes and it was problem solved. Hope this helps!
5 hours ago, doubleh said:Excellent work IMO. I would have refused the laced belt remembering how much I hated doing just a wallet known as a billfold back when I did them.
Thanks, yes a very slow process, I certainly undercharged for how long it took, but I will know for next time!
5 hours ago, YinTx said:
It all looks carved and beveled to me, not sure what you are on about?
Cheers YinTx, I admit I was a little thrown by the suggestion that it was not tooled but hopefully all cleared up now. To be fair though I may have added to the confusion by misunderstanding the initial embossing question.. In any case I have done my best now to clarify. Thanks for the kind words and well spotted on the pic, all of course traced from the same drawing but lots of small variations between these pieces.
Alex
18 hours ago, Bert03241 said:
Very good you do amazing work, sorry for the skepticism
Many thanks and no worries, it was my own bad wording!
12 hours ago, JLSleather said:Some have moved to using a PLATE IN A PRESS for belts, instead of the rollers, for exactly that
No matter. Certainly we'd all agree that your coloring is quite nice
I'm not sure if I have entirely convinced you, but I have dug up some WIP pics to hopefully alleviate any doubts about the process. So here you can see the initial swivel cuts on some of the pouches, and the scrollwork tooling on a belt, next to it's initial drawing. This was based on a design sent over by the client, so there is certainly no embossing plate involved! So yes, all hand tooled
7 hours ago, Bert03241 said:
So is it all hand carved and tooled or is it mostly embossed ?
5 hours ago, JLSleather said:"Tooled to some degree" is no answer. I could machine press a design, put a couple of knife cuts here n there, bob a couple o mulefoots in it, and call it "hand tooled" leather. It's not new - all been done before.
3 hours ago, Handstitched said:My gut instinct was right.
Sorry this is just a semantic misunderstanding on my part, I just read embossed as tooled. No there is no embossing in the sense of a big plate to do repeated designs or press in an outline, and no laser cutter etc to lay out patterns. I thought the original question was if everything I made was tooled. The 'tooled to some degree' comment I realise now implies vagueness in the context you desrcibe, but not trying to hide anything, I simply meant that I mostly make tooled items as opposed to plain/untooled!
Everything here is 100% hand carved. I draw out all my tooling patterns either directly onto the leather, or for anything where I need repeats (ie the coasters or swiss army knife cases above) it is done on paper first so it can be traced on. So no, no embossing. Just swivel knife and bevelling stamps. You will see slight differences between all of the pieces above.
5 hours ago, JLSleather said:SOMETIMES if you git wonderin' what's actually tooled, ask for something mirror image. Not rotated around by spinning the die in the press, but actually REVERSED. Or better yet, ask them to quote and do YOUR design you will provide...
I know what you mean, it is most telling on belts which use a rolling press, as the strap end can never be finished properly and the border and pattern will not taper down into the point. But yes a mirrored version of anything here would be no problem, and aside from the repeated items (which I sell frequently so keep a stock of), many of the items pictures are exactly the one off client designs you mention.
Hope that clears things up!
Alex
Thanks for the compliments all, glad you like it
21 hours ago, Sheilajeanne said:On the belts and other pieces with the black backgrounds, do you dye the background separately from the rest of the piece, using a fine brush?
Yes, exactly that. The black dye tends to bleed but will naturally stop at the cuts as long as the brush isn't loaded up too heavily, so I always paint a few mm away from the carved lines and it will bleed up to them.
18 hours ago, JLSleather said:How much of it is embossed? All of it?
Most of the stuff I make tends to be tooled to some degree, though not always and I often get asked for plain things too. As a process I really enjoy it but the look isn't for everyone.
3 hours ago, fredk said:I wish it was me, or at least that I was able to do any tooling even 1/10 as good
I'm sure you can! The tool upgrades for me made a big difference, but the bread and butter tooling techniques, eg bevelling and decorative cuts was picked up from youtube tutorials and lots of practice. Still plenty out there better than me!
21 hours ago, Littlef said:wow, that's beautiful work. I love how you used the background stamp, it really makes all the carvings pop!
Thanks, that is a Barry King bar grounder, it's become my default pretty much. I've looked at lots of ways people orient these stamps and experimented a bit when I first got them, but quite liked the look of angled even rows so that's what I do most of the time now.
Alex
Love the colour on this, and also ditto about the neat design around the lock
Hi all,
A bit of a photo dump as I haven't posted anything here in a while. I've had to compress the pics to pretty lousy quality to get them all in but you get the idea. Here is a load of stuff from the past year or so, some of it stock things and some of it custom work built to client specs.
One of my bestsellers since I started making them has been cases for vernier and digital callipers, so lots of those, as well as cases for scalpels. Then various belts, pouches, knives and sheaths. I upgraded my tandy swivel knife to one from leather wranglers, quite a big investment once you add UK customs fees but it is a big improvement, stays sharp for much longer. Ditto for Barry King stamps, I am a little jealous of the US for leather tools as shipping etc has cost me a fortune, but oh well, I doubt I'll have to buy them again. Stitching here is all by hand with waxed linen, and edge lacing is with kangaroo lace. I had never double loop edged a belt before the one here, did not realise quite how long that would take...
My real interest and most of my day job is making historical things, and so there is also a replica here of a Tudor archer's bracer from the British Museum. I made quite a bad version of this years ago when I was just getting started so it was nice to give it a revisit with better tools and experience. It was asked for with a lining, which the original does not have, and mine has no gilding where the original probably did, but otherwise a fairly close copy. Hopefully more stuff like this to come.
Anyway thanks for looking, any queries about particular pieces or tips for me to improve then fire away
Cheers, Alex
Many Thanks
On 6/30/2021 at 5:03 PM, WyattEarp said:What kind of dye and Antique do you use ?
Fiebings dyes for this. I pretty much always dilute them now with a little IPA which I find helps give an even coat. The border for this is mahogany, and the background is pro black, which is much much much better than the standard black. The tooled elements are just neetsfoot oil and the antique is fiebings dark brown with tan kote as the resist.
Thanks again all!
On 5/31/2021 at 6:34 AM, toxo said:There is light at the end of the tunnel for true artisans like yourself. The amount of "A" list customers for whom money is not a consideration is growing and they want quality over everything else. The problem is reaching them before there's nothing left in the cupboard.
Cheers! I am lucky enough to have a full time job in film, often as a leatherworker, so independent stuff like this is for evenings and weekends and thankfully I am not relying on it as my sole income! But it is nice to think that it could grow into something more further down the line.
5 hours ago, JayEhl said:Question: why is it called a 'gypsy theme' belt?
The brief for this project was include lots of gypsy imagery,- The scrollwork pattern, while virtually identical in style to Western stuff (but more scrolls, less flowers), was taken from a painted design on a vardo wagon, and the framed animal heads all have links as well.
Thanks all! Glad you like it
13 hours ago, toxo said:surely you would only do something like this for a friend because I can't see you getting back the time you put in but then again, I'm getting old and £20 is still a lot of money. Well done.
Cheers! This was not for someone I knew, and while I have made enough belts to have a reasonable idea of how much work is involved for price quotes, I always manage to underestimate how long it takes to design and sketch out tooling patterns. In this case I was not happy with my initial design and decided to start over, so several unchargeable hours from the offset. It is always a tricky balance I find as on the one hand it is easy to set a nice hourly rate, but there are definite established price brackets for this sort of product and at the end of the day I can't charge extra for being slow and getting things wrong. But with experience I will hopefully get better at this!
Alex
Hi all,
Here is an order just finished for a gypsy themed tooled belt.
The brief for this was scrollwork patterns with some animals incorporated somehow and initials tooled in. The design I went for ended up being a repeating scrollwork section based off a painted vardo wagon exterior, broken up by three framed figures of a horse, goldfinch, and game chicken. Colours were chosen by the client.
This is 3.5mm veg tan with a 1-1.5mm liner, which I find makes for a nice sturdy belt without being too chunky for everyday wear. Stitching is by hand and the buckle and keeper are held in place with chicago screws so removeable/interchangeable if needed.
Thanks for looking and I hope you like it!
Alex
47 minutes ago, YinTx said:thanks so much for the point to the Book of Kells. I've been having a creative block on a sheath I had been asked to make, this may be the key to removing that block!
Cheers, if it's Celtic stuff you're after then you certainly won't be stuck for ideas! Some of the patterns are really quite mind boggling and for me at least there would be no chance of replicating them in leather, but there are some real gems in the details that look like they would translate perfectly. Here is the reference I used for the belt
Hi all,
Here is a fairly unusual custom piece- this is a knitting belt. This was new territory for me and I had never heard of one before, but the idea is that it allows the user to knit while standing/walking. They date back hundreds of years and I'm not sure where exactly they originate but seems to be lots of ties to Scotland, particularly Shetland and the Hebrides.
This set was built to the client's specs and includes a belt, pad, and pouch.
The belt in this case is essentially a regular belt and has been designed as such- normally the pad would be integrated but having them as separate items allows more adjustment and the option of wearing the belt on its own. The tooling pattern on this is taken straight from the Book of Kells and features abstract interlocking medieval birds of some kind. A nice change from the Western things I normally do. It is 3.5mm veg tan with chicago screws to hold the buckle/keeper in place, so removable if necessary.
The pad is stuffed with horsehair and has a series of holes for anchoring double pointed knitting needles. It has three wide belt loops on the back and is a nice tight fit on the belt, this is to create as much friction as possible to prevent it sliding around when being used.
Finally the pouch has been sized to fit a ball of wool, and has an antler closing button and a tooled pattern taken from the same manuscript page as the belt design. It has deliberate gaps between the top of the gusset and the flap so that thread can pass through when it is closed.
The pouch and belt are both lined and stitching is by hand for all three pieces. This is one of those jobs that in my head was simple but ended up taking far longer than anticipated to get everything worked out, so happy to see it finished. Off to it's new home tomorrow!
Alex
7 hours ago, Sheilajeanne said:
es, of course, in medieval times, they only had knives for eating. The fork is a more modern invention:
7 hours ago, fredk said:If you look at the set on the left of this picture, back row, light brown handles, the small narrow blade is the ancestor of the fork
Yup, all eating knives other than the big ones, though I suspect general utility pieces also. Certainly not weapons in any case, or at least not designed to be.
I believe Fred is right on this, this is called a pricker and I think the general consensus is it was a multi functional fork/awl/sharpening steel. While it does go to a diamond cross section, the edges are not sharp, only the point. Here is a better image of that set.
7 hours ago, chuck123wapati said:So do you sew or form the sheath before tooling or after?
My process for these was to form them first, then unfold them and do the tooling while the leather is flat. It can't lie completely flat of course as it is stretched and distorted from the forming, but enough to carve in the designs, and in fact I find the stretch marks help for marking out the borders. Then dye, then stitch. There are probably better ways of doing this and I'm sure this will change as I make more, so open to ideas for improvement!
Alex
Thanks for the nice comments all
13 hours ago, fredk said:Whilst everyone else was looking at the Girona jewels, and the guns, I'm looking at wee scraps of leather!
13 hours ago, fredk said:At least your steel is better than the samples tested in that book.
I can certainly relate to this! Visited the museum of London not too long ago purely to look at whatever rusty old knives and sheaths were on display- not very many it turns out but still a very interesting trip for me. In terms of the steel I am feeling my way a bit and don't have the skills to pull off a forge welded laminated blade but hopefully one day, so it's nice uniform monosteel in the meantime!
11 hours ago, chuck123wapati said:Very interesting the way you / they put the seams down the center of the back.
9 hours ago, kasota oak said:Seams down the back are standard for Scandinavian puukko and leukus. Did you use/make sheath liners?
Yes fairly unusual to modern eyes, I suppose it is one method to protect the stitching from being sliced without the inclusion of a welt layer. There are some originals with side seams but a lot less common I think. Other than the the two large knives these are all unlined, which I believe was the norm.
7 hours ago, Tugadude said:It is work like this, both leather and metal, that keeps me excited about making things with my hands.
Cheers, me too! I enjoy projects which involve a few different skills, though I sometimes worry i'll end up as a bit of a jack of all trades master of none..!
Alex
Thanks all
8 hours ago, fredk said:One question: can I please see some of the seams on the back, just to see how you tackled them.
3 hours ago, DJole said:No photos of the backs, though? pretty please?
Woops, not sure how I missed this out, here you go.
8 hours ago, fredk said:As an aside: I was able to see and handle some leather work from a Spanish Armada ship and found that the stamping was very shallow, even for allowing 400 years of age
Thanks for the kind words, that wasn't the Girona by any chance? I only ask I as see you are from Northern Ireland- I was working in Belfast for a time last year and managed to visit the Ulster Museum while I was there, so may have seen some of the exact pieces you mean. Interesting about the depth of the tooling. With these I cut in the designs and opened them out with a modelling spoon, but I think with a lot of the real ones the patterns are simply drawn on with some blunt pointed tool without cutting into the surface of the leather. I have tried this but never with good results, so need a bit more practice I think.
Early days for me with knife making and In retrospect they are a little broad bladed for eating knives of this period, so the proportions will be tweaked for the next lot.
cheers!
Alex
Hi all
Something a bit different to the Western stuff I normally post here, and quite photo intensive i'm afraid... This is a batch of late medieval knives and sheaths, which as a very general outline date between 1300-1500 depending on the piece.
The sheaths for these are all 2mm veg tan, with a back central seam and tooling inspired by originals. The main source of reference was 'knives and scabbards', which catalogues pieces found in the Thames. The two larger knives have double layered scabbards, which is a necessity as the hunting set is multi pocketed with effectively three sheaths bundled together, and the larger messer has an integrated belt. None of them have belt loops in the modern sense, but are instead suspended by hanging thongs, which are laced through slits in the back and seems to be the universal carrying method for this kind of knife.
I had to go against all of my instincts with the tooling on these in an attempt for authenticity, so nothing is measured or plotted out in the way I would do a modern belt, and likewise the dyeing is much more straightforward, without the antiquing effects that would be used now.
I have focused mainly on the sheaths here as this is a leatherwork forum afterall, but for anyone interested in the knives themselves they are all hand forged from 1080 or 1075 carbon steel, with either brass or steel bolsters and handles made from various native woods, which include yew, laburnum, walnut and apple.
I hope you like them!
Alex
8 hours ago, Spyros said:
is it wise to use natural colour liners? I love the look don't get me wrong, and I've tried it too on some of my projects, but I'm yet to find a method or a treatment that will keep this interior leather clean for more than 5 minutes.
Thanks, that makes at least two people who have found that website haha! I know what you mean, and have always refrained from lining belts or larger stuff this way for that reason, and normally use pre finished upholstery leather for linings. Natural will certainly patina with age, and show marks more easily than darker colours, but for small pouches I think this is fine. The finish in this case is a couple of layers of the fiebings atom wax, buffed between each coat. I suspect this could be also used to get the worst out of any marks- actually I might take a scrap and get it deliberately grubby to test this. It won't stay looking new forever but I suppose neither will the outside really. May make some changes when batch number 3 happens.
56 minutes ago, RockyAussie said:I have only had this happen when I tried putting some leather down on the anvil piece to avoid scratches and that I found distorted the outer cap piece
I have tried with and without! I suspect it is just the snaps I am using,and just need to find the right brand. I've always found it quite tricky to find any with long enough stems which limits the options somewhat, but they must exist somewhere, I think I just need to buy samples from a few more places and experiment. Thanks!
Alex
Hi all,
Here is a jumble of small pieces completed over the past few months. I have posted variants of all these products in some form before so refrained from posting them individually, but all of them have at least small alterations compared to the first batches. In all cases these are hand stitched with waxed linen, hand tooled, and dyed with fiebings pro colours.
The pouches are for swiss army knives, I made a trial batch earlier this year which were all sold, and were all formed directly around the knife. To make a tidier and more consistent product this time round I made a custom two part wooden former, and boy did it make life easier. Just clamp it together after a small amount of hand moulding and then leave it overnight. These are all lined with milled veg tan, and closed with press studs, though I have yet to find any that don't flatten the centre to some degree when they are set, no matter how carefully done. As long as it is central and even this doesn't bother me too much but it would be nice to find a solution, all ears if anyone knows a UK supplier for slightly thicker ones.
The coaster set was for a 90th birthday present and so I could spend a bit more time than usual making them nice. For stock pieces I do not back them or stitch the borders because this would basically double the price, but that was not an issue here so I finally got to make them how I wanted.
The final batch are cases for Swann Morton scalpels, only simple little things but in my industry everyone uses them and they have proven my most popular product by far. It's the first time really I have played around with dyes that aren't some variant of brown, so that was exciting. These have a thick welt layer to protect the stitching and the tip of the sheath.
All in all a bit of a random mixture of things but I have had much better luck on the business side with smaller products than big expensive ones, which makes sense I guess. I hope you like this stuff!
cheers, Alex
Medieval Knife Sheaths (and knives)
in Gun Holsters, Rifle Slings and Knife Sheathes
No worries, I recently finished a big batch of medieval knives and sheaths and this reminds me I should upload a few newer pictures, they have come on a bit since these two.
In terms of who made them I don't have any of my references handy at present but I believe 'sheather' was its own separate profession- Googling this doesn't' bring up much but a bit of digging and you will find it mentioned. I have certainly read this somewhere in a breakdown of the various guilds involved in making a knife. As FredK mentions cutler seems to be the one that effectively commissioned the various components and assembled them into a finished product.
There is a fantastic book called 'Covering the Blade' which deals purely with this subject, and 'Knives and scabbards' is another I would recommend. I suspect I would have read about specialist sheath makers in one of those.
