llucas
Posts posted by llucas
  1. On 9/27/2016 at 4:07 PM, HENDREFORGAN said:
    Well . . we just found ourselves in a total pickle regarding this subject and our latest machine, a 205-370 which we think is an early Global clone . . it's maker's plate simply states "Fine Sewing Machine" nor does it give Country of manufacture . . and having now sewn with it we very much agree.  Getting familiar with the machine, creating a snag-list and working out what accessories we might need we notice what appeared to be the remains of PURPLE pipe cleaners left inside the needle end of the sewing head.  Given we might need to speak to the sales agent about these we took pix before removing the mangled pieces.  Then we noticed the same wire twisted pipe cleaner was attached elsewhere to the oil feed tubes . . . poo!  Had we removed something we shouldn't of?
    The pix below show what we found and where they were as well as the chopped pieces we removed, there is still some "purple fluff" left inside in places that needs cleaning out.  So we started extensive research . . what on earth did we all do before the Internet?  Pop down the local community library I seem to remember.  Durkopp Adler's parts book is rubbish for this sort of investigation, I've done technical drawing in my past and I can assure the readers that whomever drew that lot of scraggly lines knew exactly where everything went blindfolded and had no intention of passing on those facts! :rolleyes2: Worse was to follow.  We found reference on the web-site of a Scottish manufacturer of industrial pipe cleaners that ( sic ) "Perhaps less well known is their usage as the perfect “wick” to slowly draw and transport liquids and other volatile substances".  Ohh . . double poo!!  But wait . . more was to follow!  @Uwe in your excellent video about "Adjusting the foot lift" at roughly 38 seconds you can clearly see GREEN pipe cleaner inside your machines sewing head. But it got worse . . a photo on Hightex's web-site for 205-370 parts showed one of the rods we found with pipe cleaner hanging off it with ORANGE pipe cleaner neatly wound around the elbow . . . Aagghhh!!! :crazy:
    We now have to consider refitting and/or servicing ALL the lubrication system for our 205-370 given that, in all innocence, we might have disabled part of it.  We do claim at least one thing in our favour though M'Lud, not only was what we removed doing nothing but, since being removed, the machine has lost a slight tight spot when being turned over by hand.
    So . . despite all the options discussed above . . . pipe cleaner!?!  What sordid little fart thought it a great idea to wrap disposable material around thin wire and then put that in close contact with moving parts!!!
    Help?  :(
    These look like ordinary craft style "pipe cleaners" that children in schools use for craft projects. The wicks I purchased from Weaver Leather for my Adler were different in size, density, and composition. Some of the original wicks on my machine are still functioning fine. It looks like the manufacturer of your machine (Chinese?) used an obviously inferior product that was never intended for use in machinery. As I noted in a post above, I replaced most of my tubing and wicks with Adler replacements for about $9.00 USD. That is inexpensive relative to other Adler parts, for what it is worth.
  2. 8 hours ago, Big Sioux Saddlery said:
    I don't think I've ever had the problem you're having, with the glue coming back up through the holes and I use Barges exclusively. On occasion, and only very rarely, I'll have the "sticking to the needle and lifting the work" problem, and I'm normally not all that careful about keeping the glue out of the stitch line like I advised you to do. Puzzling. . . .When sewing something with a lot of wax in it, like harness leather, I'll end up with lots of wax bits in the stitch line. They usually just wipe right off.
    At first I thought it was wax coming up on the first belt -- until I tried to remove it and found it had a stretchy quality to it, lol. This is indeed a head scratcher. Brian's observation that it might be the waxy leather contaminating the Barge is interesting as well as suggesting that the Barge be thinned some. I am open to all informed suggestions at this point. It is starting to get expensive and I have four or five belt samples I need to put together for a gun store.
  3. 15 hours ago, RockyAussie said:
    Hi llucas
    Sorry to see your still having problems. I mostly don't use a lot of the veg leathers like English bridle but it occurred to me that that these leathers are a lot more oiled than I am used to and contact glue can stay quite tacky for ages.Do you have thinners for the barge? Like Madmaxx22 I also spray and usually I have to thin the glue by about 1/3 thinners to be able to spray it. Some veg jobs that in the past I have had to repair are still sticky after years. The thread I use is a polyamide multifilament called strongbond and is perhaps worth a try. It is good to burn off the ends and is very strong and long lasting. If your leather is waxy or greasy your crepe will only be good for 1 or 2 wipes. If all else fails get some silicone spray and give the belt a very light coat before stitching. (crepe will not work at all then) Best wishes
    Brian F
    Brian, thanks for the suggestions. Yes, the Barge seems to be quite a bit thicker than the Weldwood I was previously using. I'll try to thin it down and see if that helps. Do you happen to know what the solvent is for thinning? The English bridle is indeed a little waxy and as I understand it it also has tallows in it. That may be part of the problem. This is only my third attempt at using the English bridle for belts and Barge is also a new item for me. The English bridle looks fantastic -- if I can get beyond this glue issue. After reading your post I thought of a contamination solution from woodworking: using shellac as a sealer. I may try that on a scrap and see if it makes a difference. I did wax the leather before stitching (kiwi neutral shoe wax) but the silicone might be better.
    In many ways hand stitching was easier, if also very slow.
  4. And . . . it happened again! I put together a belt using 8 oz. English bridle with a 2/3 oz. natural veg tan liner. I stirred the can and applied one thin coat of Barge on each piece, gave it an hour to set up, and joined the pieces. I rolled the piece with a j-roller and set it aside for two full days to cure. Then, I turned on the Beast (Adler 205-374) and proceeded to stitch it. It pulled up cement on the stitches that could not be removed with a dried glob of Barge. Not as bad as the first belt, but still unacceptable. Even worse, the needle lifted the work piece up three times (I assume due to the cement gripping the needle) and created a longer stitch in those places. If this is normal for Barge, it is now time to throw it in the trash and use another cement. Weldwood failed (at least the can I used failed -- but only on one belt) and now Barge even more so. Is Duall 88 really better? I need a solution quick as this is getting expensive trying to fill orders for customers. I can't let these blemished belts out the door. Any of you other belt and holster makers had to deal with this issue?
    Heading to the local leather supply tomorrow as they have a crepe rubber eraser in stock.
  5. On May 13, 2016 at 8:58 AM, Big Sioux Saddlery said:
    When applying the glue, I try to keep it out of the stitch line area on projects where I anticipate this could be a problem. Also, as you have discovered, it takes less Barges to do the job than some other glues.
    Unfortunately, I need a tight seam on the belts with no separation of any kind. But this sounds like a good idea for some other projects.
  6. Thanks for all the replies. Very helpful. I switched to Barge based on reviews on this forum. I used Weldwood before, but the last time I used it a belt delaminated in a few places. So, I changed product. If I continue to have problems with Barge I will definitely try the Duall 88. Thanks everyone.
    And I will be pouring a little of the Barge onto wax paper to form an "eraser". Thanks again.
  7. 53 minutes ago, northmount said:
    Here is something that works with some contact cements.  Pour out some contact cement on wax paper or something you will be able to peel it off or and let it set.  Wad it up and press it repeatedly against the cement you want to pick up until it lifts it off.  As the surface gets dirty or less tacky, knead it some to bring new material to the surface and keep going.  Works similarly to using a wad of tape to remove sticky tape residue.
    Tom
    Great idea! Thanks.
  8. What I did was use a splinter tweezer (pointed on the end) to pull away the most obvious mini globs. I had a sample of the glue-up that I used to test the finish for the English bridle. I simply buffed the leather and then used Kiwi neutral wax shoe polish. I noticed that this sample -- which also had the pulled up glue problem since it was the cutoff from the belt -- looked much better after waxing and polishing. So I did the best I could with the tweezer; waxed it with neutral polish and brushed it out and polished it. Looked MUCH better and the client loved it. Problem solved (sort of). I have another belt done this way that I need to stitch and I will have the crepe rubber eraser from Tandy on hand at that point. If the same issue surfaces and is solved by the eraser I will post it here. Thanks for all the suggestions.
  9. 2 hours ago, OLDNSLOW said:
    I bought the one from Tandy and have used it the leather but not the thread, and it worked fine.  How long did you let it dry before you sewed the belt?  I often apply barges to both surfaces and then stick them together but I also let the item set for a couple of days if I can before sewing.
    I dried it for an hour before bonding, and used a hair dryer set on heat to speed it up a bit. The belt cured for 24 hours after bonding. I guess I used too much Barge to cure in that time. Learned a hard lesson. I did check the Tandy website as you noted and they do indeed have the crepe rubber eraser. I will pick one up as I have another belt to stitch that was glued up the same way at the same time. Thanks for the heads-up.
  10. 23 hours ago, Wizcrafts said:
    If you buy them, let us know how these erasers work out.
    Unfortunately, none of the art supply places had the crepe rubber erasers. I bought several other options, but none of them worked well. Tandy and Campbell-Randel have them and I will order one as I have another of these belts to stitch.
    20 hours ago, Thor said:
    While in town pick up one of these as well http://www.amazon.com/Mr-Clean-Eraser-Cleaner-Cleaning/dp/B004D42H5K I'm using them for a lot of tasks and they aren't as harsh as the rubber stuff. Just thinking of your thread...
    I appreciate this suggestion and my wife had one, so I tried it. It was too abrasive for this leather and did not remove any of the cement.
  11. I just stitched my first belt for a client using my recently repaired Adler 205-374. English bridle on the face, natural veg tan on the back. I also just switched to Barge cement. When I used Weldwood I always used two coats, so I did the same thing with Barge. It took longer to dry and was obviously thicker. But, it worked great when the belt straps were bonded together. However, when I started stitching the belt on the sewing machine, I noticed tiny little yellowish/white-ish debris forming around many of the stitches as the needle lifted. I checked the thread path (it is new thread) to see if there was excess thread lube (nope) and for a few minutes assumed that waxy lube was buffing off in tiny balls and that I could brush away when I was finished stitching the belt. Nope. It was little tiny bits of Barge coming up with the needle and stitches. None on the bottom; only on the top. Learned a valuable lesson: only one coat of Barge on each piece to be joined, not two. Most of it brushed off, but some is left. Anyone dealt with this before? I am assuming I can pick up a gum rubber eraser and use an edge on the stitch line to remove the remaining cement, but not sure. How have you handled cleaning up this kind of thing?
    This is not a good photo, but you can see the Barge on the stitches: little white bits.
  12. I ordered some "English Bridle" belt straps from Weaver (made in Mexico) so I could try it out on a smaller scale than a whole skin. While not "English" it is very good and not as dry as the W&C that I have. I plan to buy some full hides from Weaver and have them cut into straps for me ($11.00 charge to cut into straps -- very good deal). For what it is worth. Others may have different perspectives, but that is where I am at the moment.
  13. I am far from an expert -- I am a newbie to sewing machines and machine stitching of leather. On the repair of my old Adler 205-374 several sections of tubing and wicking was missing. I bought all the factory tubing and wicking I needed to replace everything for $9.00. For what its worth.
  14. Critique or criticism of the finished product is welcomed. Personally, I am not sure I would offer this for sale -- so I decided to wear it myself. Cosmetically, what do you think? Any suggestions to make it better? To me, things seem to be in good adjustment on the Adler 205-374, but the center foot still needs polishing on the bottom and perhaps a little less pressure? Looking at the finished product, what are your observations?
  15. I make gun belts for paddle holsters and concealed carry. They are 1/4" thick, made up of two 8/9 oz straps laminated with Barge cement. Some of my clients like the Western style buckle sets which include buckle, metal belt keeper, and metal belt tip fitted onto a tapered belt design. Problem: most of the belt tips are made for a single belt strap, not a double layer belt. Same problem with the belt keeper. I have been carving/skiving the leather tip and letting it into the belt tip. Scalloped edges on the belt tip offer another complication. This works, but introduces an inherent weakness into the tip of the belt. Does anyone have a source for metal belt tips that are made to accommodate +/- 16 oz of leather? I have looked everywhere; quizzed my current sources but have drawn a blank. It is a lot of work fitting a belt tip designed for a single strap onto a double layer belt.
    Here are two examples of what I have done to make this work:
    5700851dc219f_taperedbelttip1.jpg.55b282
    570085357dd51_taperedbelttip2.jpg.7ba96b
  16. 4 minutes ago, dikman said:
    Yes, I found an edge guide to be indispensable on anything longer than a couple of inches!! Actually, I reckon it looks good (bottom too) and once it's dyed and finished off it'll probably look even better!
    I'll put up a photo or two when the belt  is finished. Thanks for your feedback. I will definitely use that edge guide next time, lol.
  17. Based on the comments here, I nervously sewed my first belt on the Beast today. Since I did not like the stitches on the back when I did the finished sample posted above, I decided I would sew first (since the belt will be dyed black) and do edges and apply finishes after stitching. The Beast chugged along about one stitch per second -- slow compared to the skills of others, but much, much faster than my hand stitching. I also reduced the number of stitches per inch to five instead of the seven pictured in the above post. The top thread is 277 and the bottom thread is 207.
    Here is the front stitch:
    Here is the back stitch:
    I did not use the edge guide; free handed it instead. I should have used the edge guide, lol. Comments/criticisms are welcome.
    56f9d869024f6_firstbelt1.thumb.JPG.878f5
    56f9d87b75600_firstbelt4.thumb.jpeg.c4d6
